![]() ![]() Drives: Toyota Vitz 2007 facelift Join Date: Jan 2012
Gear disengage or keep on D
Hi,
I just wanted some clarification as there are many differing opinions on this issue. On my CVT auto Yaris Sedan (known as a Belta here) whenever I stop my car at a signal I used to shift to N instead of leaving the car on gear i.e. D drive and keeping the brake pedal pressed. After many told me that this would lead to gear problems I leave the gear stick on D and keep the brake pedal pressed when stopping at signals and in traffic jams, I have been doing this for quite sometime now. The only thing is that lately, when I press the brake at a signal the car vibrates. Will anyone please clarify what is the correct way when stopping at signals on a CVT driven auto car? Also hope @CT Scott can read this thread and give his opinions too :) Thanks Tyrone |
#2 | |
. Having to do this while driving a 2013 Yaris rental with under 19k miles on it brought back memories ( ) of the 2-3 years out of the last 30 when I didn't have at least one car with a manual transmission.
Automatics, including CVTs, are intended to be driven stop and go, so there is no reason to shift to neutral when stopping. Vibration when stopped is normal with the Yaris, as the ECM really drops the RPMs when you are stopped to conserve fuel.
#4 | |
re this was really thinking about 'pressure building up' with one's foot on the brake. I remembered this feeling from years ago, and had the same feeling (to a lesser extent) in the 3rd Gen rental. I didn't hear/feel the RPMs drop in the rental (couldn't see, no tach). Perhaps in both cases (the 3rd Gen rental and memories from the past) the idle was too high?....although I'd hope they'd keep their in house rental on a maintenance schedule that would prevent this.
Thank you CTScott for your reply...that really helped ease things out.
Jcboy will check the intake manifold and engine rubber mountings too. Thanks |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
According to my scangauge in my auto RPMs do drop when stopped in D however the gallons per hour goes up vs. In N the RPMs do go up but GPH will drop .03 GPH to .1 GPH.
#8 | |
![]() ![]() ![]() Drives: Sedan 07 Join Date: Oct 2012
The vibration is probably due to either a dirty Intake Manifold/servo/whatnot (thus the very low idle=vibration), or a worn engine mount rubber. |
| Tags |
| ct_scott |
| Experimenting with bypassing the AT 4th gear prohibition when cold | CTScott | Performance Modifications | 28 | 03-22-2015 08:16 AM |
| Toyota C160 Reverse Gear Problem | Parmas | DIY / Maintenance / Service | 2 | 12-01-2010 01:30 AM |
| Gear oil change choices (Canadians) | Jem_hadar | DIY / Maintenance / Service | 17 | 08-29-2009 11:51 AM |
| New Owner - Lights on Gear Shift | javagirl | New YARIS Purchase Forum | 8 | 05-22-2009 02:23 AM |
| clicking into first gear | tekmoe | General Yaris / Vitz Discussion | 9 | 11-01-2006 02:44 AM |
