![]() Drives: 2014 Yaris L 5spd Join Date: Apr 2014
New Yaris Break In Period...
... and how to get it back to Springfield, IL from Chicago, IL which is approxiatemately a 250 mile trip. How should I do this efficiently?
I'm going up to the Chicago, IL area on Tuesday and will most likely be buying a new 2014 Yaris L manual transmission. This thought about the break in period just crossed my mind. Do you guys think I'll be alright driving it back home, even though it's mostly highway driving? I could take some backroads for a bit but even those will probably be county highways. So what do you guys think?
Take the highway. Just keep to the posted limits, and no jack rabbit starts. The highway will be better than back roads.
![]() ![]() Drives: 2008 Liftback Join Date: Nov 2010
I've always heard to vary your speed/rpm's a bit. Maybe do a stint in the final gear but break it up every now and again by using 4th gear (if a manual) or take out of overdrive (if auto).
You could also slow down (60~65, if on interstate) for a spell and then bring it back up to 'cruising altitude' after a couple of miles.
AMSOIL Synthetic Lubricants Direct Jobber |
I don't think it even matters on our engines nowdays.
Toyota engines supposedly come already broken in. |
25, 550 MILES!
You'll be able to vary the speed on Interstate 55 between Chicago & Springfield no problem. Don't beat on it and don't go hard on the brakes for awhile.
Mine came from another dealership (Henderson, NC to Boone, NC) about 200 miles away. IIRC it had about 220 miles on it when I picked it up in Boone. Hope everything goes well with your purchase...! |
I see no problem at all. Go as fast as you need to and use those brakes for all they are worth if necessary!
Only Happy When it Rains
I don't think break in is necessary at all for the Yaris. Just be gentle at first and change the oil at about 1000 miles and you will be fine.
Colin Chapman disciple |
According to the OM the first OC is 5k miles so theres no break in.
I think a 1k OC makes a lot of sense though.
Funny how folks will say 'you don't need a break-in' but then follow-up with something else that's just as similar like 'change your oil at 1k mi'.
The truth (according to OEM practices) is that you: A) don't need a break-in time B) you can drain your initial oil right on a normal schedule C) you can break-in fresh engines with synthetic oil I don't believe in or adhere to their suggested practices. They are in the business of selling cars. If you get 140k miles on your Yaris, you'll be OK with that and you'll be well out of warranty. But what if I want 300k (or more) miles out of mine? What's the best practices to follow in that instance? So, in my opinion, it's a safe bet to baby the car (and brakes) a bit when new (I mean, don't put yourself in harms way - if you need to accelerate to keep from getting run over, DO IT!) and change the factory fill oil and filter a bit prematurely on the first go around. I don't think any of that is really necessary, necessary. But for maximum longevity, it sure can't hurt. $0.02
#10 | |||
^ the point is that engines nowdays don't require the same care they used to.
If you stick to the maintenance schedule and do mostly highway miles, you will hit that 300k miles in no time without any issues. |
HAHA.. the first week I had my Yaris.
picked it up on a Wednesday sometime in August of 2010, it had about 20 miles on it pre-registered for the next Autocross event drove it to work the next 2 days (~50 miles total) drove it to the autocross event on the following sunday (~300 miles) Slapped on some R-comps to run HS class and drove the crap out of it Came in first in my class (compitition was a Legacy and a Golf) Drove back home the same day. Realized the potential this car had Autocrossed once a month and sometimes 2 times a month and 1-2 track days each year since that day. Currently have almost 70k miles on my car now with oil changes every 5k miles and No other maintence. Even my drive belts are not showing much sign of cracking. My brake pads are still original and I still have about 6-7mm left in my front pads. (i checked 2 weeks ago) I also do not have an issue with my waterpump going bad, even with the NST underdrive pulley kit (crank, water pump, and alt)
25, 550 MILES!
![]() Cool...! I guess it doesn't matter what you do to with a Yaris, it is invincible!!! ![]() Personally, I'm driving mine like an old man (that I am slowly becoming) Cars need to be driven, I guess no matter how soft or hard. As long as you bring it up to full operating temp. once a week or so, it'll be fine. I just can't see spending 14 grand on a new vehicle & then driving it hard. To each their own. Now my old Chicago Winter beaters back in the 80s, that was a different story
#14 |
| Natural Gas Yaris | MadMax | General Yaris / Vitz Discussion | 13 | 06-03-2017 06:10 AM |
| 2010 engine break in period? | rapev-8 | New YARIS Purchase Forum | 22 | 10-22-2012 12:26 AM |
| My 2012 Yaris review... | CanIHazYarisHatch? | Third Gen Yaris General Discussion | 35 | 02-20-2012 01:03 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
