![]() ![]() Drives: 2009 Yaris, 1994 HiLux Surf Join Date: Nov 2013
turbocharging a yaris...a theoretical question
I have read a few turbo-ing a car guides, saw a few youtube videos and all share the same thing. they all say you should get some kinda new aftermarket ECU, since the air entering will be different and the engine will run lean.
My question is, cant the MAF sensor detect the change in air flow? Cant the stock ECU adjust the fuel injected accordingly? |
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
It does not have enough range to cover boost. They map the engine to handle all intended conditions. They are not going to waste time developing tunes to handle boost for a handful of enthusiasts
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Obsessed with 1.5L
That being said...my tercel handled 3.5lbs of boost perfectly with no tuning.
so an aftermarket ECU is a must?
does the Blitz Supercharger come with an ECU? I have read that it makes about 7psi of boost.
The Surf is still here.... But now there is a Yaris next to it! |
Modded Moderator
Drives: 07 Toyota Yaris, 71 Galaxie Join Date: Mar 2007
Moved to the forced induction forum.
#6 | |
http://shop.microimageonline.com/BLI...BLITZ-SC-Y.htm |
![]() ![]() ![]() ![]() ![]() Drives: Toyota Yaris Sedan 09 STD Join Date: May 2009
You need a return style fuel system and a 1:1 fuel pressure regulator. That will help you a lot when the boost comes on.
so I downloaded the online install guide and the thing has about 40 components and there is no ECU....the only electrical thing I can see is a relay, some harnesses and connectors. if that thing is adding 7PSI with out any chip tuning, wouldn't it be possible to achieve this with a turbo for a far less price?
#9 | |
![]() ![]() ![]() Drives: 2009 Yaris Join Date: Jan 2014
Unless I'm wrong, someone can correct me. Personally, I wouldn't boost mine unless I built up an engine for it. With the amount to invest in a good Turbo, mind as well go all the way and do it right. My 2cents |
#10 | |
| Selling my Yaris - Clutch Replacement Question | Swoleslaw | DIY / Maintenance / Service | 9 | 11-05-2011 11:27 AM |
| Yaris 2005 custom HU question | stroebs | In Car Entertainment + Electronics (audio / video / alarm) | 7 | 01-05-2011 08:30 AM |
| Just bought my Yaris - drink holder question. | ceily | General Yaris / Vitz Discussion | 24 | 06-21-2009 10:10 PM |
