Old 05-27-2014, 06:53 PM   #1
NEexpat
Drives: 2009, auto, 4dr LB
My Fiamm El Grande install
Just completed my Fiamm install. Wow, maybe because I'm used to the "meep meep" these are loud and well worth the $20 + change cost from Amazon.
Chose these over others because it is my understanding they draw less than 10 amps, so while there is a relay included, the less wiring, splicing, cutting, T-tapping I'm involved with the better. So I opted out of the relay. Others, don't take my advice, you do so at your own risk.
Several days ago I was hoping to ID the part number # for the female F connector on a Toyota premium horn install harness. I wanted that part to make my own harness. Well on my cyber travels I could plainly see that a lot of the "meep meep" horns, the flat round Denso's have that clip or one like it riveted to the back horn.
I went to the Pick and Pull got a horn off a Corolla drilled out the rivet got the clip home, dremeled off the plastic around the connector made my own harness and sealed it with some liquid tape.
I decided to just remove the bumper cover as well as the black, spacer clipped above the radiator, there is a threaded hole to left of the horn bolt that I used for the second horn
Anyway, quite simple really, the hardest part is taking off the cover and replacing it. I painted the brackets flat black, taped off both ends though, the bracket acts as the ground on these setups so that metal on metal has to be a good clean surface contact.
I liked the little grills over the mouth of the horns. I just didn't care for them being shiny silver, so removed them and painted them black as well.
Thanks again Yarisworld!
Cheers.
NEexpat is offline   Reply With Quote
Old 05-27-2014, 06:58 PM   #2
Nice! That's a resourceful way of getting your hands on that elusive connector.
Old 09-06-2015, 11:47 AM   #3
LugNut
Drives: 2007 2DR Liftback
Thumbs up It was a tought choice, but ...
After reading this and many other threads here on louder horns, I just ordered the set, FIAMM 74100 El Grande, for just under $20. Added a few other little things I needed to get free shipping on Amazon.
Keeping the OEM wiring, relay, and hopefully the 10A fuse, as well as decent two-tone, louder than stock without being obnoxious (or illegal ... but do like those train horns!), and mounting location were key factors in my choice. But, of course, so was the sound produced:
https://www.youtube.com/watch?v=UsBHUm6adC8
Thanks for the info! I'll likely make a custom jumper, but time will tell.
The current housings are shown as red, so I'll likely paint them black. And will remove/recycle those grilles which are there for looks (and would very slightly reduce the sound level, but also slightly increase the reverberation if still installed).
What drove the need for this mod, and the dash cam, was a guy who almost hit me while backing up in his 3/4 ton pickup down a street. He apparently couldn't see me, nor hear me laying on the Yaris's horn despite his windows being open.
LugNut is offline   Reply With Quote
Old 09-06-2015, 08:08 PM   #4
nookandcrannycar
My grandfather always drove a Lincoln or a Cadillac during my lifetime. Whenever he got a new one, he'd take it to a guy he knew who would install a horn that sounded like a Southern Pacific locomotive (if it was illegal, I don't think he knew it was , or perhaps he didnb't want to know ) . He loved trains. One of my favorite 'grandpa memories' was, at 5 years old, sitting up on a hill on a friend's ranch (just the two of us, for most of an afternoon) watching trains go by and counting the different types of cars.
Old 09-06-2015, 01:16 PM   #5
CoryM
Drives: 2009 5-door, 5-speed
I bought my car as a rebuilt and the OE horn was not only damaged, but the wiring was also damaged. Making the already mild OE horn just plain sad. I went for the El Grande as well and highly recommend it. It has a nice sound, and one that is not out of place for a Yaris (no point honking and having people looking for the truck instead of you). It's definitely loud enough to get people's attention which is the whole point of a horn.
I did use relays and HEAVY gauge wiring to ensure I am getting maximum sound levels out of the horn. It's pretty loud, but would have to compare to one spliced into the OE harness to see if there is a difference.
Cheers.
Old 09-07-2015, 11:12 PM   #6
shepd
Drives: 2007 Yaris 5 door RS
Depends on how your laws are written where you, but in some places, you can have a horn as loud as you would like (well, 194 dB is the law) so long as you ONLY *EVER* use it to inform other drivers of an emergency situation.
Old 09-08-2015, 01:35 AM   #7
nookandcrannycar
. Different jurisdictions....different definitions of emergency situation? I've been in the slow lane on the freeway or a multi lane in each direction surface street going the limit or 5MPH under and many of those times had idiots (sorry...mostly young....I hope I wasn't like that at that age ) start to bear down on me and at the last second move to the next lane (without signaling ) on the left, barely missing the rear left corner of my Yaris and then driving as close to me as poissible...then as soon as they pass me..they center themselves in their new lane .....if only for a few seconds before moving on to another lane without signaling . I only sometimes do it, but honking in such a situation FEELS appropriate (I looked it up recently....doesn't seem as though appropriate).
Old 09-08-2015, 03:07 AM   #8
shepd
Don't worry, I put air horns on my previous car because the city installed a bunch of roundabouts but didn't do much educate drivers on how to use them. It is amazing how, when the horn is loud enough, you can guarantee you will see brake lights!
I consider any situation that could cause an accident an emergency. Never had an issue yet, even used my air horn within a few feet of a cop car when I was being cut off, no response.
So, as far as anecdotal evidence goes, go for it. Just keep the honking for dealing with dangerous drivers. It's people that get air horns and use them to scare pedestrians who are assholes. :)
Old 09-08-2015, 04:26 AM   #9
nookandcrannycar
Many places (but not all) in my county.....one rarely has to be concerned about more than an occasional pedestrian.....because there aren't very many of them.
Old 09-08-2015, 08:03 PM   #10
LugNut
Thumbs up
Just got the El Grande's in from Amazon:
The red on them are just decorative plastic covers, and fell off both mine easily. The factory had applied one small dab of caulk-like glue to hold each cover on, but each had failed. No problemo, due to the below.
The grilles came off easily via prying carefully with a tiny flat screwdriver. The grilles are chromed, thin steel.
A traditional car "horn" is actually a combination of a sound source ("speaker", "voice-coil", etc.) and its expansion horn. This set seem to have conventional sound sources in galvanized steel housings, but the attached horns are black plastic instead of the traditional painted-black steel. But they sound fine, and hopefully will last many years.
I bench-tested each "horn" -- HI and LO notes, each with the red plastic thingy and the discharge grille on and off, separately. No matter what the combination, the horns sounded about the same. The human ear is not that sensitive to slight sound level changes, though, and electronic test equipment in a reverberant room probably would show a slight change in loudness and sound-spectrum distribution.
Bottom line -- nice sounding horns, for cheap! They give that big, American car sound. I'll install the set this weekend, hopefully, without the red covers and grilles. And like in the good pictures above, with the shiny steel facing backward so only the black horns are visible through the Yari's grille.
Old 09-12-2015, 12:27 PM   #11
LugNut
Thumbs up Installed! Sound great.
Well, that was easy! And they sound great.
I painted the two steel mounting brackets flat black, except where they mated with the horns and the body (for ground). Also made a custom Y-splitter using 18-gauge wire -- the OEM green wire is dinky; even smaller.
Worst parts of the jobs were 1) didn't have a proper thread/length SI/metric bolt for the second horn (on left), so had to retap that hole to 1/4 in. SAE, and 2) the little plastic push-pin retainers for the bumper cover (seven, I think) were very brittle from age, especially the two in the wheelwells (one each). I'll put them on my long term to-buy list; was able to reuse the old ones for now.
It was a bit unnerving pulling the bumper cover off their tabbed mounts to the front fenders, but went fine. As others say, there's no need to remove the 10mm screws from underneath, just gently tilt the cover forward. I wedged my rubber mallet's head right in the middle between the cover and the actual steel bumper to hold the cover forward.
As done above by another psoter, I also removed the black plastic cover over the bolt holes so that I didn't have to make a cut-out in it for the new second bolt. Removing this snap-on cover was interesting -- I ended up using a little flat screwdriver to push the two tiny retaining tabs inward while applying gentle pressure to pull each tab out. Do both end tabs first to reduce twisting the last one. And remember to reinstall this black cover before the bumper cover.
Old 09-12-2015, 04:29 PM   #12
shepd
Well, in the mountains, the law is lower than 194 dB. :D
Old 09-12-2015, 09:08 PM   #13
nortonfb
Drives: 2007
The mountains of Kitchner?
Must have missed that.
nortonfb is offline   Reply With Quote
Old 09-13-2015, 08:19 AM   #14
LugNut
Unhappy
On using train-like air horns on the road, here's the first few hits that came up on my Google search:
http://thelawdictionary.org/article/...air-horn-laws/
http://forums.officer.com/t89150/
http://www.tenfourmagazine.com/2013/...law-june-2013/
So I read them as saying legal to own/install, but not to use on the road. But !
Old 09-13-2015, 06:31 PM   #15
tomm9050
Drives: Yaris 2008 HB
Is there any way to make the turn signal indicator louder?
tomm9050 is offline   Reply With Quote
Old 09-13-2015, 10:36 PM   #16
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
Would be nice, but what's the point?
People hardly ever use them anymore these days.
Old 09-14-2015, 02:50 AM   #17
nookandcrannycar
This ^^^^^.....and it is worse here, IMO, than in the other large metros in the U.S. and Canada. The drivers are worse (than here) in parts of Florida, but they use their turn signals more often .
Old 09-13-2015, 11:01 PM   #18
LugNut
Used to be that the "flasher" could be replaced with a louder, heavy-duty version meant for when towing a trailer (and thus needing to power its signals too). It's a relay for the indicators and the hazards, and for old US cars was in a small steel can that looks like a big capacitor. Should be under the dash. Yari have such?
))) Tein Super Compact coilover install tips ((( aucorium DIY / Maintenance / Service 4 10-25-2011 12:42 AM
HELP needed for carputer project: Powered USB hub install Astroman In Car Entertainment + Electronics (audio / video / alarm) 15 11-01-2010 05:18 PM
fiamm el grande horns installed staypuft Cosmetic Modifications (Exterior/Interior) 14 08-22-2010 08:29 PM
