Old 06-06-2014, 03:14 PM   #1
bebeelo
ThatYarisGuy
Drives: Toyota Yaris 2012 SE
throttle body missing a part
okay so I just bought a 1zz throttle body online and I just received it today. but its missing the part(idk what its called, probably like a coolant hose port). the picture that I attached is not the actual tb that I have but shows two of them. Im missing the short one that is pointing straight up. is this fixable?
bebeelo is offline   Reply With Quote
Old 06-06-2014, 03:51 PM   #2
You can just bypass it (take the two hoses that connect to the TB and just connect them to each other). The only purpose of the coolant connections to the throttle body are to heat the intake air, to improve fuel economy when the engine is cold.
Old 06-06-2014, 04:35 PM   #3
bebeelo
ThatYarisGuy
How can i connect them together? So even though its missing one of the tb coolant hose will there be any gaurantee that it may not function correctly?
Old 06-06-2014, 09:28 PM   #4
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
You'll be just fine.
Our Yaris has been running that way for months.
I just used a small scrap of aluminum tubing to couple the two coolant hoses together.
Old 06-06-2014, 04:42 PM   #5
mazilla
advocatus diaboli
mazilla's Avatar
Drives: 07 Yaris hatch
Kinda lame that you got a broken(?) part but otherwise no it will not harm anything to bypass. I bypassed mine for a couple of years before finally hooking it back up since I happened to be messing with it.
-Type 07 FFL-
My odometer 03/11
Old 06-06-2014, 05:16 PM   #6
bebeelo
ThatYarisGuy
Yeah actually i bought a 1zz tb, which i thought it was in good condition but arrived in the condition i explained from the first post. Btw How do you connect the two hose together to bypass it? I cant get a good picture of how to do it. Btw is it also normal to have the 1zz tb not close all the way? Theres a very tiny gap.
Old 06-06-2014, 07:23 PM   #7
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Yes, the valve should not close all the way. If it did, your engine would stall every time you took your foot off the gas pedal.
The bypass is on the hose itself, not the throttle body--connect the hose ends to each other, not to the TB.
Old 06-06-2014, 10:39 PM   #8
Rigaud
Drives: 2009 Yaris
I didn't connect the two hoses. Even simpler and cleaner I removed one hose and only used one to loop back.
The 1ZZ I found online was rebuilt as new, sand blasted and clear coated. Got it for $68
Old 06-07-2014, 03:48 AM   #9
bebeelo
ThatYarisGuy
it all makes sense now. thanks so much guys!!!
TPS reading at WOT with 1ZZ throttle body? 4/20 NEVER FORGET Performance Modifications 14 07-02-2023 04:20 AM
1zz Throttle body review/tips Black_griffin6 Performance Modifications 154 11-18-2021 03:35 PM
Throttle Body Cleaning? shangapol DIY / Maintenance / Service 14 08-04-2017 02:09 AM
Carbon build up in the throttle body Sedan DIY / Maintenance / Service 18 11-15-2013 11:44 PM
Throttle Body Swap questions... Stove Performance Modifications 0 06-27-2010 03:31 AM
