Old 04-22-2007, 02:53 AM   #1
Wow, I Got 48.57 mpg
okay, i just filled up after my Santa Cruz trip, and calculated my mpg. i got 48.57 mpg! most of that was freeway driving, but i was averaging 70 mph, hit stop and go traffic on the way out, and using the A/C. parts of the trip was downhill, so i was cruising that part in neutral. but man, that's some good mpg. lol...the best i've ever done was 50 mpg.
Old 04-22-2007, 03:12 AM   #2
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
holy snap...
nice!!!!
-- Blen
Old 04-22-2007, 03:27 AM   #3
BailOut
Steals terrorist's lunch
BailOut's Avatar
Congratulations!
- Brian
Share the Road
Old 04-22-2007, 04:13 AM   #4
thank you all.
Old 04-22-2007, 04:14 AM   #5
Congratulations!
so does this confirm that i don't have DFCO? like i said, this was mostly freeway this tank...but when i did try using DFCO like you said, i ended up losing 2 mpg.
Old 04-22-2007, 04:19 AM   #6
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
If you ask me DFCO is BS anyway,because when you let off the gas your still in gear so there is a drag on the engine,so you slow down.Ive found tht giving it just enough gas to cruise(may drop mph allitle going straight,but I pick up goig down hill),or putting it in neutral,no drag there.
eco is offline   Reply With Quote
Old 04-22-2007, 04:20 AM   #7
yeah, but the DFCO concept seems valid, but i just don't think my Yaris has it. so i'll stick to putting it in neutral.
Old 04-22-2007, 06:30 PM   #8
falkor_99
falkor_99's Avatar
Drives: 07 Yaris Blue HB
Send a message via AIM to falkor_99
thats pretty damn good!!!
falkor_99 is offline   Reply With Quote
Old 04-22-2007, 09:23 PM   #9
nebulight
Novice Hypermiler
Drives: 2007 Toyota Yaris
Send a message via AIM to nebulight
This post is pissing me off! I've tried to drive in the lower RPMs, turning off my car at lights, pumping up my tires to 50psi, DFCO, turning the car off while going downhill, you name it. And the best I was able to get was 37mpg on the highway, and I just filled up today and got 34mpg city!! What am I doing wrong?!
It's a slow start, but I'm shooting for 45mpg by summer. Best so far is 42.23mpg
nebulight is offline   Reply With Quote
Old 04-22-2007, 10:42 PM   #10
Speedz
Will work for Yaris...
Speedz's Avatar
Drives: Yaris
Perhasp the engine havent run in yet...?
Like diesel engine can achieve the 1k per tank when the engines did about few thousands ks...
Speedz is offline   Reply With Quote
Old 04-23-2007, 02:10 AM   #11
i wouldn't turn off my car at lights. starting your takes a lot of gas, from my experiences. you probably don't have DFCO, like me. if your Yaris is a stick-shift, try coasting to a stop sign/light, and down hills (has to be at least a mile imo) in neutral. that's what i do.
Old 04-23-2007, 10:35 AM   #12
blacksan
blacksan's Avatar
Drives: 07 Bayou Blue Liftback
My driving is about 50/50 (town/interstate) and I have never had mpg that low? I do drive with real gentle input to the throttle and keep my speed at approximately 65 mph on the big road. My average is 43 mpg.
Do you have a bunch of extra stuff (weight) in the car? Do you accelerate briskly from stops? Are you using cheap (no name) fuel? Has the car been properly serviced?
blacksan is offline   Reply With Quote
Old 04-22-2007, 10:32 PM   #13
Edd
Drives: None
Wow, that's like 4.85L/100km (if I worked it out correctly)... :-) [That's using the "US gallon" not "imperial gallon" - even though they are both imperial measurements.. Jesus the world would be screwed without the metric system.]
Edd is offline   Reply With Quote
Old 04-23-2007, 12:31 AM   #14
YarisGuy
Drives: 2006 Yaris
WOW, very impressive indeed!
YarisGuy is offline   Reply With Quote
Old 04-23-2007, 02:12 AM   #15
thanks.
Old 04-23-2007, 10:48 AM   #16
Sabina74
Yaris Lover!!!
Drives: Yaris 1.0 Sol 5 doors liftback
Send a message via MSN to Sabina74
WOW! that's incredible!
with my 1.0L i get 40 mpg!!! i thought it was good...!!!
Sabina74 is offline   Reply With Quote
Old 04-26-2007, 06:18 PM   #17
Edd
Drives: None
Oh, sorry KL, I misinterpreted what you said.
Old 04-26-2007, 10:17 PM   #18
it's all good.
Synthetic oil MPG boost since change Yaris Dick General Yaris / Vitz Discussion 29 09-15-2007 09:15 PM
Increased MPG or HP anyone???? slvryaris Performance Modifications 55 05-27-2007 11:49 AM
To accurately measure MPG when should I fill back up. mgthompson General Yaris / Vitz Discussion 17 03-30-2007 11:07 PM
Rims, Tires, and MPG Pavel Olavich Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 03-23-2007 08:28 PM
Yaris Mpg query Vanguard General Yaris / Vitz Discussion 3 03-18-2007 10:56 AM
