Old 09-05-2014, 07:37 PM   #1
firebird1999us
firebird1999us's Avatar
Drives: 2003 Mach 1
Cool Yaris S gauge cluster install in my 2009!
Took 10 minutes max and works like a charm!
firebird1999us is offline   Reply With Quote
Old 09-05-2014, 09:39 PM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Did you have the odometer matched? I swapped mine out but didn't bother since MI only requires you to note the existence of the discrepancy, not the difference.
Old 09-05-2014, 10:48 PM   #3
I matched the odo for him.
Old 09-05-2014, 11:58 PM   #4
axiom
axiom's Avatar
Drives: 2007 Yaris
Man! How do I get one of these?
axiom is offline   Reply With Quote
Old 09-06-2014, 12:36 AM   #5
Kalispel
Kalispel's Avatar
Drives: '15 Yaris SE 5MT
Forgive my ignorance, but how is the "Yaris S gauge cluster" different from the base gauge cluster? Tachometer?
Kalispel is offline   Reply With Quote
Old 09-06-2014, 07:34 AM   #6
For the US market, prior to 2010 only "S" Yaris had the tach.
Old 09-06-2014, 01:26 AM   #7
bladesmith6
Drives: 2007 yaris HB
ctscott is the bomb! i had him switch the leds to blue and match the odo reading, love my cluster.
bladesmith6 is offline   Reply With Quote
Old 09-06-2014, 08:50 AM   #8
ezhacker1
ezhacker1's Avatar
Drives: Decepticon - Ravage
Wow I haven't seen a S cluster in a long time, you , I and few others have these and not the Canadian ones.
Now I'm still hoping for a digital LHD one
Check out my Build thread:
Old 09-06-2014, 08:56 AM   #9
firebird1999us
Drives: 2003 Mach 1
Big thanks to CTscott for programming the correct mileage and shipping it down here for me! I know it's more less just a cosmetic mod but I missed not having a tach and didn't want to do a non-matching aftermarket piece. Install was really a piece of cake!
Old 09-06-2014, 10:03 AM   #10
axiom
axiom's Avatar
Drives: 2007 Yaris
Seriously, how'd you get it? I would love to get one. Thanks!
Old 09-06-2014, 12:53 PM   #11
I had picked that one up from a local junkyard quite a while ago. The S ones are very hard to find, as there are not many of them around, let alone wrecked.
I can also convert Canadian ones to have he odometer increment in miles and have the outer ring of the speedometer indicate mph, rather than km/h. The Canadian ones are way easier to find, as tachs were not just for S models up there.
Old 09-06-2014, 12:49 PM   #12
Kar98
Drives: 2011 Scion tC
I forgot, is there such a thing as instrument cluster for a manual Yaris 2, with tach?
Old 09-06-2014, 09:56 PM   #13
Only 2010+ for the US.
Old 09-06-2014, 09:28 PM   #14
ezhacker1
ezhacker1's Avatar
Yeah its pretty rare to see any S yaris. Came down to luck for me to snatch it off of the forums.
Old 09-20-2014, 07:22 AM   #15
beaker
Drives: 07 Yaris 3 door
I have an 07 Yaris hatchback, auto trans, non abs.
If I wanted to do this upgrade, what cluster do I need to look for? Anyone have a part # or which model yaris to look for to get a cluster out of? Will a sedan cluster work in my hatchback?
Thanks
beaker is offline   Reply With Quote
Old 09-20-2014, 07:56 AM   #16
Thanks
Sedan cluster is a different shape and has a different connector. You need specifically an 07 or 08 S cluster without ABS. I don't have the part number handy, but there is only one cluster that meets that spec.
For non direct solutions, you can use an 09-11 cluster, but all 09+ have ABS, so the ABS and BRAKE lights would have to be disabled or they would always be on. For 2010-2011 the TRAC light would also have to be disabled.
Old 09-20-2014, 08:36 AM   #17
beaker
Cool, thanks for the answer.
Which of the clusters you have listed above also have the cruise and foglight indicators that I could also utilize when I add these options to my car?
Old 09-24-2014, 08:56 PM   #18
None would work for cruise indicator for your 07 (as the ECM on your 07 would not send the proper message to the cluster to light it). All would have the foglight indicator, as your current cluster does as well.
Yaris 2 D4D 2009 without AC serpentine belt rasyaya DIY / Maintenance / Service 6 07-17-2014 09:02 AM
2009 Yaris and wind sailing GrayYaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 10-26-2013 07:52 PM
how do I install a different headunit in 2006 yaris? wouterw In Car Entertainment + Electronics (audio / video / alarm) 10 05-13-2013 07:55 AM
