Old 10-05-2014, 07:57 AM   #1
CB900F2
Drives: 08 Sedan
Rumble when breaking between 60kmh and 50kmh
Hi all
In the past few months my 08 Sedan (auto) has developed a rumble through out the car while I am braking aggressively that only happens while the car is slowing down through 60kmh down to 50kmh..
I replaced my front rotors thinking that was a possible issue. and it is not a pronounced, but still happens..
There is no shake in the steering wheel, nor any feedback through the brake peddle..
Any thoughts?
Thanks all!
Forgot to ask also.. Anyone had any issues with the mounts on the Yaris?.. will be checking them out to see if there are any issues with them.. The one under the battery looks a bit tough to get a look at its condition with out having to remove the battery tray etc...
CB900F2 is offline   Reply With Quote
Old 10-05-2014, 01:34 PM   #2
woops
Drives: Jeep Cherokee XJ 1996
the mount under the battery tray is often overlooked, i've replaced those on about 5 cars in the last two months.
Most people / mechanics do not bother to give it a good look.
regarding your 'rumble' when braking...
I'd check the RIM / wheel temperatures after a normal daily drive
if a front rim/wheel is hotter than the other, it probably means a sticky brake calliper piston or a bad wheel bearing...
same goes for rear wheels but IIRC they have drums at the back, right?
woops is offline   Reply With Quote
Old 10-05-2014, 02:34 PM   #3
aspro
Warped rotors will cause a rumble as well as air in the brake lines. Did you have the brakes bled recently?
TRD sway bar, h&r coilovers, tanabe strut tower bar, konig feather, bfg sport comp 2, MI intake manifold, aem cai, dc header, trd catback, MI crank pulley, trd short shift kit, phillips hid kit, morimoto led fogs, parrot navi indash, alpine 6.5 speakers, alpine amp, alpine reverse camera, led interior lights, thule roof racks, netz badges...
aspro is offline   Reply With Quote
Old 10-05-2014, 08:10 PM   #4
aspro
I just properly read your post. I take back what I said. If you're not feeling anything in the brake pedal and you replaced your rotors then chances are it isn't your brakes. Maybe stabalizer links? Or bushings in that specific area of the drivetrain?
Old 10-10-2014, 09:11 PM   #5
CB900F2
Drives: 08 Sedan
Thanks aspeo.. Going to check the various bushings next...
Old 10-06-2014, 06:47 PM   #6
CB900F2
Drives: 08 Sedan
Hi Woops.. What was the symptom of the issue with the bad mount under the battery tray?
Thanks
Old 10-10-2014, 09:08 PM   #7
CB900F2
Drives: 08 Sedan
Checked rim temperatures after a drive to work and no real differences between each front and rear sets. Only like a difference of 2 deg c..
Old 10-05-2014, 03:14 PM   #8
woops
yeah but the OP mentioned that rotors have been replaced
Old 10-05-2014, 09:34 PM   #9
woops
no worries
to add to the topic
if it has drums on the rear they might as well need some looking at
Old 10-07-2014, 05:06 AM   #10
woops
the furious vibrations of the 4cyl at idle going on throughout the body
Old 10-10-2014, 09:10 PM   #11
CB900F2
Drives: 08 Sedan
Don't suspect being any of the motor mounts as the car drives very smooth and between shift is smooth, and at idle again very smooth...
Dam. This is ticking me off..
Old 10-11-2014, 12:35 AM   #12
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Have you checked the drums in the rear? jack up the rear and give each wheel a spin. Check for tight spots in the rotation. If it's free, give the e-brake one click until there starts to be resistance. It should be a consistent feel.
Old 10-11-2014, 06:15 AM   #13
CB900F2
Drives: 08 Sedan
Hi Bluevitz.. I checked them, but not in this manner.. I will check them today as suggested.. thanks Blue!
Old 10-11-2014, 09:19 AM   #14
nobodywise
nobodywise's Avatar
Drives: Yaris sedan
This exact think used to happen to me then I put aftermarket wheels on and got it serviced and it just 'went away' so I didn't question it
I love the back of my car, the front... not so much
nobodywise is offline   Reply With Quote
Old 11-01-2014, 04:56 PM   #15
CB900F2
Drives: 08 Sedan
Update: After taking into account the various suggestions, I decided to purchase a set of new drums and the rumble is gone..
Might have been some run out with in the drums I assume... or maybe poorly balanced drums..
Bought some second line drums, to replace these defective Beck Arnley drums...
