![]() ![]() ![]() ![]() Drives: toyota yaris yrs Join Date: Jun 2007
Gearbox issue.
What does it mean when the car is off I can't put it in gear. But once I press the clutch it goes in gear.
You mean without the engine running?
Not sure exactly but theres no practical significance!
Gearbox issue.
There is no significance. Because the car is not running, so trying to move the gears without the clutch on a non-moving gearbox gets you to some point that the gears don't align..
You pretending to be a 10 yr old sitting in a car, shifting, and making neat power shift sounds with your mouth?
It means nothing. Sometimes when a car is sitting at rest, engine off, the gears will be aligned and you can throw the shifter through the pattern. Sometimes the are not aligned and you cannot engage the shifter without pressing the clutch.
I've had other manual cars before i can shift 1st,2nd,3rd,4th, to 5th to reverse with the engine off and back no problems. But with this car i can but sometimes it refuses to go to any gear with the car is not running you know me just playing around with it.
I was thinking something is wrong with the gearbox. Apart from having a notchy 2nd and 3rd gear. It's funny because in the cold it's sometimes smooth and other times it's notchy galore. LOL. Time to replace it??
![]() Drives: 2007 Yaris Join Date: Sep 2011
What it means? Your trans is functioning normally. Congrats.
Wanna prove it? When on flat ground in neutral, release the parking brake. ever so lightly pull the shifter towards second gear. Now open the door, put your left foot on the ground, and while still holding the shifter towards second push the car backwards using your foot. Before the car even rolls 1 inch, the trans will slip into second gear like butter. |
#8 | |
Enthusiast
Drives: 07 Yaris HB 1.3 (EU) Join Date: Nov 2014
Vrrrrrrrrrrr - choo choo BANG! (flames from exhaust)" Hahahahahahaha Sent from my HTC Explorer A310e or my awesome Xperia Z1 C6903 using Tapatalk.
Cheers, George. |
| Gearbox breaks at 110,000km on Yaris 2007 | sven337 | DIY / Maintenance / Service | 10 | 07-26-2014 08:06 PM |
| yaris voltage issue | yaris2010RS | DIY / Maintenance / Service | 11 | 12-29-2012 05:20 PM |
| Water Pump issue, after taking in for Recall | GeneralDon7 | General Yaris / Vitz Discussion | 34 | 05-27-2012 09:04 PM |
| 08 HB DRL Issue | BruceLee | Cosmetic Modifications (Exterior/Interior) | 3 | 02-18-2012 11:59 PM |
| CONSUMER REPORTS : MARCH issue reviews '09 YARIS . | gid | General Yaris / Vitz Discussion | 93 | 01-06-2009 05:10 AM |
