![]() Drives: 2009 Yaris sedan Join Date: Aug 2014
Odd exhaust issue
I recently bought a 2009 Yaris sedan which was well optioned and well cared for. About 2 months later, it has developed an exhaust noise. The muffler shop says it's a cracked exhaust manifold. Is this a common problem. The shop says they've never seen it on a Toyota before.
Cracked ones are very uncommon on our cars, as the OEM manifold is welded tubing, rather than being cast. My bet is that rather than a crack that it is the gasket between the manifold and the mid pipe. That soft metal gasket is a far more common failure point.
Cool. I knew the Corolla was tubing but just assumed this one was cast since the tech mentioned "cracking".
Typical muffler shop incompetence. |
![]() ![]() ![]() ![]() Drives: 2009 5-door, 5-speed Join Date: Sep 2011
It's much less common with steel manifolds, but can still happen. I'm with CTScott though, probably a gasket. If it's a primary exhaust leak (the tubes coming from each port, before the collector) it will sound more like a * tack tack tack* noise. Especially when cold starting. If it's just a steady, louder noise, it's after the collector.
Cheers. |
Would it sound like a sorta vacuum leak under load while driving. Ive had something similar but cant find the source
![]() Sent from my iPod touch using Tapatalk |
#6 | |
Cheers |
![]() ![]() ![]() Drives: 2007 Yaris 5 door RS Join Date: Nov 2014
A broken exhaust manifold / header will make a ticking noise, and you may smell exhaust in the engine bay. Although you may get that (but louder) if the donut is broken.
| Odd throttle issue | mr_miles | DIY / Maintenance / Service | 21 | 11-01-2014 09:20 AM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Enkei's and Dunlops + Medalion Touring Exhaust | 2manywheels | Items for Sale by private party | 40 | 04-04-2011 05:01 PM |
| does BACK-PRESSURE increase MPG vs straight thru... | marcus | Fuel Economy Forum | 25 | 05-03-2009 09:23 PM |
