Old 11-22-2014, 06:12 AM   #1
hondajt
hondajt's Avatar
Drives: 2013 Yaris LE 5Dr
vent selector switch seems stuck/difficult to turn
Anyone have this problem? It's really difficult to turn and on a cold morning it's nearly stuck.
Looking for fun!
hondajt is offline   Reply With Quote
Old 11-22-2014, 07:23 AM   #2
That is a common issue and often results in snapping the cable or popping it off the back of the knob. Pull the glove box and check the vent selector (the other end of the cable) while rotating the knob. There is a clear plastic grease on it that may be gone, or it may simply be that there is some moisture in the air box that is freezing the flappers in place. For that there is not much you can do, other than wait until it warms up to change the output position.
Old 11-24-2014, 07:09 AM   #3
hondajt
hondajt's Avatar
My car is covered under a comprehensive warranty still, I'm probably just going to take it to them.
The switch also seems sunken in. Like, its about half and an inch shorter than the rest of the switches.
Looking for fun!
Old 11-25-2014, 06:44 AM   #4
hondajt
hondajt's Avatar
Here's a photo
Looking for fun!
Old 11-25-2014, 06:45 AM   #5
hondajt
hondajt's Avatar
I assume that's not normal?
Looking for fun!
Old 11-25-2014, 08:02 AM   #6
Corsair
Corsair's Avatar
Drives: 2010 Toyota Yaris
Mine is very stiff when cold, I just try to warm up car before i move it.
Corsair is offline   Reply With Quote
Old 11-25-2014, 11:19 AM   #7
hondajt
hondajt's Avatar
Does anyone else's first switch sit more inward than the others like in my picture? I'm concerned that's not normal.
Looking for fun!
Old 11-25-2014, 11:34 AM   #8
That is not normal. Either the tabs that lock it into place broke or have just popped free.
Old 11-27-2014, 06:21 PM   #9
jcboy
Drives: Sedan 07
Yeah the first switch sitting a little inward is a tell tale sign that something is not right. hopefully it just wasnt seated properly and not a broken tab.
Old 12-09-2014, 09:32 AM   #10
hondajt
hondajt's Avatar
Dealer says it isn't covered under warranty, but hasn't done anything, they just looked at it, called, said it's not covered, do you want it fixed. I said I was disappointed it wasn't covered and I'd get back to them.
I'm 90% certain it's a broken tab on the knob. I assume they think so too, and are thinking it's misuse/physical abuse, and that is why they don't want to cover it. The only problem being, I didn't do that, it was like it when I purchased it.
Thoughts?
Looking for fun!
Manual Transmission Vent tmontague DIY / Maintenance / Service 3 09-08-2022 10:09 PM
Sound when making a left turn (a water flow sound) jimmydie DIY / Maintenance / Service 9 06-20-2013 05:35 PM
Projectors retrofit, black reflectors and dimmed front turn signals my2sense General Yaris / Vitz Discussion 11 06-20-2012 11:39 AM
Are rear red turn signals planned for Yaris as well ? 77W General Yaris / Vitz Discussion 38 02-22-2010 06:41 PM
Will local bay area members please stand up! YarisSedan California 264 07-28-2009 11:53 PM
