![]() ![]() Drives: 09 Yaris Hatchback Join Date: Oct 2014
Boostedtrd turbo log!!
![]() ![]() ![]() Drives: 2013 Yaris Hatchback L Join Date: May 2013
Fantastic! Please take tons of pictures my good sir!
Sweet. I love build threads..
I may have missed it in another thread. Whats the plans for this one?
#6 | |
My HP Goals are 300+Build Plans: Head: -Port & Polish -Supertech Scion TC valve springs and retainers (good results according to Blown_xa) -Stock Valves since I can seem to find anyone that makes over sized valves - Golden Eagle intake manifold with 1zz Throttle body Block -CP Pistons 9.5:1 -BC Rods -ARP Head Studs -Factory Head Gasket -Factory Main Bearings. -Factory Rod Bearings. -Factory Thrust Bearings. -OEM Rear Main Seal. Fueling- Golden Eagle Fuel Rail with Fuel Pressure regulator Walbro 255 Fuel pump Denso 550cc injectors whatever else I need to make the fuel return system Clutch -ACT 6 Puck Clutch Exhaust -Custom Tuning -Will be done by Ptuning since they tune Blown_xa car and he was tuned with Haltech sprint 500 and that's what I have. |
http://www.yarisworld.com/forums/sho...ghlight=valves
I know these were sold already, but did you check this company out? I could have sworn Garm had some up in his online store before. Have you talked to him also? Maybe he knows someone.. worth a shot if not being able to find them is the issue and money isn't.
#8 | |
![]() ![]() ![]() Drives: Scion xA Join Date: Oct 2009
looks good man. When it comes time to assemble the motor I will give you a heads up about a couple things. Those ARP head studs will require small modification to a couple of things for fitment
Ptuning.com |
Thanks bro, I really appreciate your help with my build. Mad props to you
won't you need to do some machining to accommodate larger valves if you do decide to go that route anyway? I'd assume a larger valve will require a larger diameter port and larger seat to work effectively.
Yup your right, I don't if its even worth the time and money to get larger valves installed, unless they give you some sick hp gains.
![]() ![]() ![]() Drives: 2002 JDM Vitz 1.3 Join Date: Feb 2013
So many builds start off great then go silent, I will admit that I'm guilty of this too
2000 JDM Vitz [2NZ-FE Crap-otmatic] < Now Manual Conversion complete Follow me on Instagram: instagram.com/itzkingjustin |
#14 | |
Mr. 155 and climbing
time for this kind of stuff is always a factor as well as getting pictures moved and hosted, etc. posting progress is time consuming as well. hopefully we will see more on this soon as I enjoy them myself. I will be curious about the turbo setup and exhaust manifold choice.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yoda's Turbo Log | Yoda | Forced Induction Forum | 404 | 08-17-2013 07:22 PM |
| FS : GT2560R Turbo + Manifold | Parmas | Items for Sale by private party | 0 | 08-24-2012 08:35 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
| curious about micro image log type turbo manifold ! | jenfre | Forced Induction Forum | 9 | 10-18-2010 10:41 PM |
