Old 04-28-2007, 02:30 AM   #1
Nibs
Nibs's Avatar
Drives: 07 Yaris HB black
idle rpms up and down...
wondering if this is normal or not.
When I'm in nuterel at a stop the rpms fluctuate every couple of seconds anywhere from .5 to 1 rpms. This is still after the car is well warmed up. could it be the break in period still? only 300k so far.
anyone else have this on their yaris?
Nibs is offline   Reply With Quote
Old 04-28-2007, 06:53 AM   #2
it's normal, nohting to worry about, basically just the engine doing this to help keep clean emissions
Old 04-28-2007, 09:31 AM   #3
hystria
hystria's Avatar
Drives: 2007 Orange Yaris Hb 3Drs
engine idle fluctuate between 500rpm and 1000 rpm ?
absolutely not normal, go see your dealer
hystria is offline   Reply With Quote
Old 04-28-2007, 10:52 AM   #4
Doug007
Doug007's Avatar
Drives: 2007 Yaris S Sedan
Mine will fluctuate between 750 and 500. I've been told that is normal.
2007 Silver Streak Mica Yaris S Sedan 5 Speed
dojo TSUKAMI Shift Nob
Brake Light Pulser
Daytime Running Lights
http://www.webelectricproducts.com/products.htm
Doug007 is offline   Reply With Quote
Old 04-28-2007, 11:17 AM   #5
eco
eco's Avatar
Drives: 2007 Black Yaris sedan
I have SGII,mine will go from 575-750 at idle,In neutral it goes to 900rpm.It will also drop when the fan comes on at 202 degrees.
eco is offline   Reply With Quote
Old 04-28-2007, 11:36 AM   #6
Nibs
Nibs's Avatar
interesting. My old car started to do this when the temp sensors were starting to go on it... but normal function on the yaris hehe.. weird. I just wanted to make sure I wasn't the only one with my engine doing this
Old 04-28-2007, 12:18 PM   #7
eco
eco's Avatar
Try not to worry,its fine,when ever you need somthing,or have somthing to say,just drop in to your friendly neighborhood Yaris/Vitz/Belta/ community,YarisWorld.com
Old 04-28-2007, 01:49 PM   #8
Nibs
Nibs's Avatar
Thx man. Love the site.
Old 04-28-2007, 03:21 PM   #9
hystria
hystria's Avatar
with OEM rpm cluster (Canadian model), the rpm stays at 600rpm when engine is warm, with no fluctuations.
Old 05-12-2007, 12:59 AM   #10
naossoan
Drives: 07 Yaris 3DR
It is NOT normal for your idle to fluctuate that much.
My car is still pretty brand new, it has around 500 km on it.
After warmup, my idle is pretty much rock solid with the needle sitting around 500 rpm, a little bit below.
What you're mentioning is what used to happen with my old Honda Accord that had over 250k on it the idle would go from about 750 - 2000 rpm back and forth non-stop
i dont know what the problem was as I got rid of the car cuz i didn't want it anymore....but i know it was a problem
naossoan is offline   Reply With Quote
Old 05-12-2007, 03:39 AM   #11
Pars
Drives: 07 Yaris Liftback
Occasionally, I'll notice my tach fluctuate a little at the lights while in neutral from between 400rpm to 600rpm. But it rarely happens and seems to occur when driving condition has changed, otherwise it's normally steady. Like, when I came back from a 2hr driving trip from the highway while averaging 90mph and when I was back in the city, the rpm was a little twitchy until engine got used to the more sedate city cruising.
However, fluctuating from 500rpm to 1000rpm all the time seems a little extreme. Perhaps you should try using premium fuel at a popular gas station until the car gets a good brake-in. If you haven't taken it on the highway, then opening the engine up a little on the highway might smoothen things out.
Pars is offline   Reply With Quote
