![]() Drives: 2011 toyota yaris Join Date: Jan 2015
How to make a duplicate transponder key?
Hi guys,
I lost my only key for 2011 yaris. There is an engine immobilizer on it. So, I have to make a transponder key. The quote from dealer ship is around $400, I think it costs too much. Is there any other way to make it? Thank you guys! |
You have to have one of the other original "master" keys to add a new one and the Toyota Techstream tool is required to program the new key into the ECU.
Hi Scott, unfortunately, I don't have any original master keys. I bought the second hand car, only come with one key, but I lost it.
That will be a problem. I believe that without one of the original master keys the transponder key ECU has to be replaced with a new one in order to register a new key with no existing keys.
Do you mean I have to replace a new ECU? How much will it cost?Could I buy a transponder key from ebay and let the dealship cut and program it?
It's not the key that they are charging you $400 for. It is the Transponder key ECU (89780-52061) which is about $300 plus the replacement key (89785-60160), which is abut $35.
#7 | |
Where did you find the part number? Does it require VIN to find the correct part number for my car?? |
No need for master key to program new keys but u need to reprogram ECU by obtaining a 6 digit code directly from Toyota this will wipe the ECU old security and reprogram with new with and new cut keys don't know why they are charging u so much tho it's about a 15 min procedure with tech stream online with Toyota plus cost of keys and remote.
Sent from my iPhone using Tapatalk |
#9 | |
#10 | |
Thanks for your useful information. How much will it cost generally? Dealership told me they have to order a new key from toyota for $165, together will other costs, almost $400. but the key is much expensive than ebay. could I buy a new key myself? |
Yes I have done one on a sienna ..same problem person lost all but one key no masters .
In order to do this I had to log with Toyota and its full of security as in they need my name , blood lol etc after that I get the code that basically resets the whole security and at this time u can load blank keys as ECU is reloaded but like I said only Toyota employe can do this and one has to be verified . But this is completely different procedure from just adding keys with that u need master for simple add on of lost key with out special security protocol . Sent from my iPhone using Tapatalk |
#12 | |
#13 | |
By the sounds of it they are doing the manual route and charging for something that just need programming with new security . Sent from my iPhone using Tapatalk |
#14 |
They said to order a new key for $165, and look for code/cut/program/, totally about $400. I think it cost too much.
#15 |
But yes the other code u mention is for key cut . All other is to reprogram the security.
| Deactivating the lost key. | vicky | DIY / Maintenance / Service | 6 | 11-14-2014 12:19 PM |
| I lost my master keyless entry key, need suggestions.... | Frankd1 | DIY / Maintenance / Service | 19 | 12-01-2010 11:13 PM |
| Replacement key / keyless entry | mcduck | DIY / Maintenance / Service | 4 | 08-30-2010 06:52 PM |
| Need remote key | fraenx | DIY / Maintenance / Service | 1 | 06-26-2009 07:29 PM |
| MJ dead | 90tsi | Off-topic / Other Cars / Everything else Discussions | 28 | 06-26-2009 02:20 PM |
