Old 03-23-2015, 10:44 PM   #1
New TSB - 2006-2015 Yaris Drive Belt Squeal Noise on Cold Start
This new TSB for "Drive Belt Squeal Noise on Cold Start" was recently added for the 2006-2015 Yaris.
The solution is simply a higher belt tension spec:
Original spec:
New Belt: 539-637 Nm
Used Belt: 245-392 Nm
Updated spec:
New Belt: 750-850 Nm
Used Belt: 375-400 Nm
Attached is a copy of the TSB.
06-15 Yaris Drive Belt SqueakT-SB-0012-15.pdf
Old 03-24-2015, 01:18 AM   #2
jason214
Drives: 2007 Yaris Hatchback
Thank you for the information.
jason214 is offline   Reply With Quote
Old 03-24-2015, 06:13 AM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Soon to follow: TSB for premature failure of water pump and alternator bearings. =)
Old 03-24-2015, 06:30 AM   #4
BINGO!
Old 03-24-2015, 11:13 AM   #5
bronsin
bronsin's Avatar
Hmm
Old 03-24-2015, 11:55 AM   #6
Tgawe
Drives: 2013 Toyota Yaris
Interesting. Does this mean anything for someone who bought a new belt and got it tightened twice to stop the noise from somewhere other than a Toyota dealership? My car is outside the 36k and/or 36 month range so I expect this doesn't really affect me.
Tgawe is offline   Reply With Quote
Old 03-24-2015, 02:22 PM   #7
It's a TSB, so your warranty parameters mean nothing. This is just an advisory to mechanics for trouble shooting a customer reported issue.
Old 03-24-2015, 02:21 PM   #8
Original spec:
Updated spec:
So, for us driveway mechanics who measure tension by belt deflection, what do these new specs mean?
Interested tidbit in the TSB, 'Do not loosen Bolt B', the bolt that has caused countless people grief. Countless post in here on the issue of stuck, stripped, or broken bolts stemming from tightening or replacing the belt.
Old 03-24-2015, 02:51 PM   #9
woops
Drives: Jeep Cherokee XJ 1996
What a bulletin, way to go toyota ;)
woops is offline   Reply With Quote
Old 03-24-2015, 03:26 PM   #10
matti
Drives: 2017 Yaris L (5sp manual)
My car squeals like this sometimes!
matti is offline   Reply With Quote
Old 03-24-2015, 05:42 PM   #11
fnkngrv
Mr. 155 and climbing
fnkngrv's Avatar
I can't see the TSB. Is this for both 2 and 3 pulley setups?
Old 03-24-2015, 05:47 PM   #12
Shinare
Bronze bombshell yaris
Shinare's Avatar
Drives: 09 Yaris HB 3door
Thanks for the info. Just a week ago I fixed my belt noise by increasing the tension on the belt to as hard as I could pry the alternator over. This makes me feel better about doing that. Heh. I have no way of finding out how tight the tnesion is but I figure its not too bad since I have very little strength. lol
Old 03-24-2015, 06:19 PM   #13
Yes
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
**SAFETY RECALL!! 06-07 YARIS HB & SEDANS** slvryaris DIY / Maintenance / Service 83 09-30-2012 12:25 PM
