Old 06-08-2015, 01:21 AM   #1
LeetViet
Drives: 07 Yaris 4DR
How to remove console by parking brake in hatchback?
Trying to determine if my Yaris has an existing AUX cable that I just need the plug, or the entire assembly to plug into the OEM unit. I did a few searches, but couldn't find a guide to remove the console by the parking brake in a hatchback.
Also, would anyone know before I pry it open, if my unit supports AUX?
LeetViet is offline   Reply With Quote
Old 06-08-2015, 10:38 AM   #2
I don't think your unit supports AUX. From what I've seen, units capable of supporting it have an AUX button on the face.
To remove the console, remove a bolt/screw located in the bottom of the cup holder. If you then lift up on the rear of the console, it will release itself from some retaining clips.
Old 06-08-2015, 06:05 PM   #3
Correct - That headunit is not directly compatible with the OEM Aux jack.
Old 06-13-2015, 06:08 PM   #4
LeetViet
Thanks guys. I ordered a new head unit + trim + wire harness from Crutchfield.
DIY (08' USDM LB): Interior Light Color Change revnull DIY / Maintenance / Service 37 05-21-2016 12:59 PM
The brake story: frequent disk warpage Lux DIY / Maintenance / Service 20 11-01-2014 12:25 PM
Question replacing head gasket. Snyprwlf47 DIY / Maintenance / Service 3 07-13-2014 11:17 PM
09 hatchback black console jeremyshay Cosmetic Modifications (Exterior/Interior) 1 01-15-2009 02:30 PM
