clunk in steering - steering shaft
I've had a clunk in my steering on my '02 Echo for a while now. I've replaced the sway bar end links as they were worn, new struts, regreased strut mount bearings, and replaced inner and outer tie rods.
Everything else looks fine including the control arm and ball joints. When my hand are at 3 and 9 position the wheel moves a bit as well as the steering wheel even when locked. I think the steering shaft is gone and needs replacing, more specifically the yolk sub assembly (u joint). Does anyone know if I can replace this without dropping the sub frame? And is it accessible from under the steering wheel? Rock auto has the shaft or just the yolk sub assembly which is cheaper. Since I'm assuming just the yolk sub assembly is worn is that an easier part to replace? Thanks in advance |
| DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag | CTScott | DIY / Maintenance / Service | 307 | 04-04-2023 04:43 AM |
| The Yaris Steering Wheel | wornways | General Yaris / Vitz Discussion | 12 | 10-09-2012 02:41 PM |
| Steering column compatibility between Euro Yaris and US Yaris | Micropurchase | Third Gen Yaris General Discussion | 19 | 09-17-2012 01:00 PM |
| Steering wander, adjusting EPS assist | Snubba | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 05-22-2012 06:39 PM |
| How much would you pay for a warranty supported steering wheel extension? (3d try) | wornways | General Yaris / Vitz Discussion | 36 | 09-16-2009 11:16 AM |
