Old 07-07-2015, 12:54 PM   #1
esse10
Drives: 2009 yaris 2 door
jacking up the car
Anybody ever lift the car using floor jacks under the control arms? Will that damage the control arms ? kinda like where I have the red arrow at in this picture?
esse10 is offline   Reply With Quote
Old 07-07-2015, 01:14 PM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Old 07-07-2015, 04:47 PM   #3
nookandcrannycar
Old 07-07-2015, 01:22 PM   #4
tmontague
tmontague's Avatar
Not where you put the arroow, but on my Echo because the underbody is so rusted I jack up just under the subframe. I then place jacks on the sides behind the wheels.
I have done this for the past 2 years with no issues, I just do so carefully. I have also jacked the control arm up to put weight. On the suspension when I replaced the end links. I did this when they car was resting on jacks under the sides.
Old 07-07-2015, 08:32 PM   #5
2009Toyotoad
Drives: 2009 Yaris 3dr
Likely you'll bent it. Not a good call.
2009Toyotoad is offline   Reply With Quote
Old 07-07-2015, 11:31 PM   #6
Exiwolfman
Exiwolfman's Avatar
Drives: 2007 Yaris
Not a problem it's fine do it all the time on alignment rack and no u won't bend ur control arms.
Sent from my ASUS_Z00AD using Tapatalk
Old 07-08-2015, 09:05 AM   #7
esse10
thanks
thanks, kinda what I thought but needed more confirmation from past experience folks or realtime mechanics
Old 07-08-2015, 12:56 AM   #8
Freestylin
Freestylin's Avatar
Drives: 09 Blizzard Pearl RS LB
^ Big lady says no... no. no. no..
“On a given day, a given circumstance, you think you have a limit. And you then go for this limit and you touch this limit, and you think, 'Okay, this is the limit'. And so you touch this limit, something happens and you suddenly can go a little bit further. With your mind power, your determination, your instinct, and the experience as well, you can fly very high.” ― Ayrton Senna
Freestylin is offline   Reply With Quote
Old 07-08-2015, 09:52 PM   #9
CoryM
Drives: 2009 5-door, 5-speed
Closer to the balljoint, but yes it is fine to lift there. Just be aware that the ctrl arm can angle when jacking. If your jack-pad is steel, it may slip off so watch that. I prefer to jack on the subframe bolts etc.
Cheers.
Old 07-11-2015, 09:52 AM   #10
hachi-roku_fan
Drives: 1986 Toyota Corolla
Is there a reason why you aren't using the usual lift spot? Like Cory stated, the control arm is a pivoting piece and will move as you're lifting, which is why most people don't do it
hachi-roku_fan is offline   Reply With Quote
Old 07-13-2015, 04:51 PM   #11
esse10
jacking up
just checking my options, but I believe using the subframe is a better place to jack up the car. thank y 'all for the replys
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Car Buying Scams nemelek Off-topic / Other Cars / Everything else Discussions 1 09-29-2011 08:01 PM
thewifesyaris - photo scavenger hunt thewifesyaris Photo-Video-Media Gallery 0 03-01-2009 06:02 PM
