![]() ![]() Drives: 2007 toyota yaris sedan Join Date: Jun 2015
Power door locks the door, but does not unlock. All other locks are fine. Just that front passenger side door.(front right door).
I hear and see all doors lock but when i press to unlock no sound at all for that right front door. 2007 yaris sedan i only have two lock switches located in the front side doors. Please need insight on this. |
Is it really the door lock actuator?
I read the post you sent. I'm not sure if this is the problem because the door does lock from this particular door! from the inside. And unlocks and opens with a key from the outside. I just doesn't lock when i push that switch to unlock it from the inside front passenger side door. The thread you posted deals with a person who can't get the door to open or closed from a particular door from the inside. I just can't unlock it from the inside. If you need more details please ask. |
It may still be the actuator. It may also be binding of the cable to the manual lock lever. The key directly flips the lock assembly, so it really is not a good test. If you use the manual unlock lever inside does it feel stiffer than the driver side?
This morning i tested the lock and it works now.
This is so weird. Thanks i will check soon. |
| WTB: Passenger Side Foglamp | white_rice | Items for Sale by private party | 3 | 03-18-2012 09:28 PM |
| A/C only blowing out of passenger side? | devinlamothe | DIY / Maintenance / Service | 24 | 08-08-2011 05:50 PM |
| New carbon fiber front lip and side skirts. | Yaris PAVEL94 | Cosmetic Modifications (Exterior/Interior) | 17 | 12-19-2010 03:01 PM |
| How hard is it to remove side skirts and front lip on 08 sports package? | dono37 | Cosmetic Modifications (Exterior/Interior) | 15 | 09-26-2007 05:28 PM |
