Old 07-20-2015, 06:01 PM   #1
avs262
Drives: Yaris 08 sedan
2008 Yaris knocking/rattling sound near drive belt
I have a 1.3L Yaris manual transmission that is knocking/rattling near the drive belt. I've searched around on here and found that this could be caused by the water pump so I replaced the water pump and drive belt last night. The water pump did have antifreeze all around it so I thought for sure that was the problem. After replacing I fired up the engine and the problem continues. I've taken a video (https://vid.me/VLYv) so you can hear the noise - has anyone experienced this? My next step is to go buy a stethoscope. Any other ideas would be greatly appreciated!
avs262 is offline   Reply With Quote
Old 07-20-2015, 10:43 PM   #2
avs262
It turned out to be the a/c unit. I listened with a stethescope and loud knocking could be heard from the a/c. I used a serpentine belt from a non a/c configuration to bypass it until I figure out what's wrong with it.
Old 07-21-2015, 02:30 AM   #3
valchrist90731
Drives: 2007 toyota yaris sedan
But does the a.c. work when on? Does it blow cold air?
How's the pulley? That's a different noise never heard that yet.
valchrist90731 is offline   Reply With Quote
Old 07-21-2015, 05:34 PM   #4
avs262
The a/c does work when it's turned on (I don't use it often) and is blowing cool air. I will check the pulley and report back.
Old 07-21-2015, 04:15 AM   #5
Mikastef
Drives: Yaris
Do u use the air con often..? If not, then it should not be the AC unit
Mikastef is offline   Reply With Quote
How many miles you got out of Yaris drive belt? waruna01 DIY / Maintenance / Service 12 06-09-2015 01:01 PM
Yaris with new audio DPS module installed - Gadget or really increasing sound quality Flyingmatdes New YARIS Purchase Forum 8 04-19-2011 12:50 AM
2008 Yaris S driving belt socjo1976 California 9 03-16-2011 05:52 PM
