![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
heads up on the third brake light
it was not working. i googled and didn't find much on yaris, but some other toyotas had problems with dry solder inside. i took it apart and all components (4 LEDs, 2 resistors, and a diode) and connections were ok. i greased the connector with dielectric grease and it works now. all it needed was dielectric grease on the connector pins.
funny how no one cared, LOL.
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
Every now and then I back up to a store front and check my lights for function. So far, the third brake light hasn't failed on mine yet.
Well, the fix didn't stick for long. It had been off for quite a while. Anything else to try?
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
can you test electric connections wile it's plugged in? check voltage before and after each component (LED, resistor, diode) and see where it stops. that will tell you where the issue is.
or you buy a new one: part #: 81570 52210 |
it must be intermittent as it worked today.
i also noticed to see it working during daytime, one has to be exactly behind, not much light shows up off center. |
there is one for sale in the market place for $10. cranky's clearance or something...
#9 | |
Marketplace is a forum here in which you will find the Items for Sale sub-forum.
#12 | |
too bad i didn't see it earlier. i got tailights from some asshole on ebay who didn't bother to ship it one week later. |
| ABS light on (without parking brake light) | WildChild | DIY / Maintenance / Service | 15 | 05-06-2018 12:40 PM |
| 2010 Yaris Replace 3rd (center) brake light | waruna01 | DIY / Maintenance / Service | 5 | 05-13-2015 01:07 AM |
| Speedometer, brake light, odometer all gone weird | boneyking | DIY / Maintenance / Service | 0 | 07-01-2014 01:30 AM |
| third brake light bulb fault | Geoff Peace | DIY / Maintenance / Service | 4 | 06-29-2011 01:32 PM |
| Help Needed - Brake Light Question | *MAD DOG* | Cosmetic Modifications (Exterior/Interior) | 21 | 02-08-2009 05:32 AM |
