Old 09-28-2015, 07:35 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Question Strange OBD II code: C3201
Got the car back from the mechanic last week (replaced clutch) and among the DTCs that were present is this strange one: C3201. No info on it on the net as a generic code, nor a Toyota specific code. Has anyone seen this before? CTScott?
Old 09-28-2015, 08:58 AM   #2
dj92
Embracing Curves
dj92's Avatar
Drives: '14 Prius Executive
Maybe just a glitch?
Or does it return instantly?
I drive, therefore I am.
dj92 is offline   Reply With Quote
Old 09-28-2015, 02:10 PM   #3
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
No information on this code? Strange!
Try to use a different scan-tool and see if the same code pops up. I've heard some ODB scanners can glitch out sometimes and give you wrong codes.
Old 09-28-2015, 02:49 PM   #4
If I read this correctly, the code was present on last trip to garage and cleared. It is not reoccurring.
One thing I can find for C3201 is a compiler error. Maybe the diagnostic machine was reporting its own fault.
Old 09-28-2015, 03:02 PM   #5
Wait...here's something
http://www.ford-trucks.com/forums/98...ml#post9204540
Old 09-28-2015, 06:54 PM   #6
dj92
Embracing Curves
dj92's Avatar
Just been so curious to try it out.
However, a pulled driver's seat belt fastener just gave me a B-dunnoanymore.
It did not appear on a plain OBD-Tool either.
Old 09-28-2015, 08:18 PM   #7
C is chassis related DTC. For example the TPMS gives C21xx codes, VSC C14xx, ABS is C02xx an C12xx.
On the Yaris, SRS Codes are Bxxxx codes (as opposed to that ford listing). I have never seen C32xx listed, so it may just be an anomaly of the shops reader.
Old 09-28-2015, 08:55 PM   #8
The Ford listing is for diagnosing a B2292 fault. It then drills down to a C3201 (drivers side pretensioner).
Old 09-28-2015, 09:07 PM   #9
Yes. On Toyotas pretensioners are still B codes.
Old 09-29-2015, 04:46 AM   #10
CrankyOldMan
As far as I know, it was not present when it went in to the shop. It's showing up on my ScanGauge II. I haven't cleared it yet--have a rental for the week for work--but I will definitely keep an eye on it.
Old 09-29-2015, 10:58 PM   #11
CoryM
Drives: 2009 5-door, 5-speed
I had a quick look at work and couldn't find that DTC on any Toyota related product. Nothing even close to (maybe) narrow down what system.
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 09:03 AM
P0010 OBD engine Code crazylegs DIY / Maintenance / Service 1 08-27-2015 08:27 PM
full tank japle Fuel Economy Forum 15 12-10-2013 12:05 PM
P0456 OBD code? jlift DIY / Maintenance / Service 6 09-19-2007 04:28 PM
Anybody know the code? Driver New YARIS Purchase Forum 5 08-20-2006 07:56 PM
