Old 09-30-2015, 06:30 PM   #1
BobTheYaris
BobTheYaris's Avatar
Drives: '08 Yaris HB 2 dr
HELP Car Won't Start
Its an '08 Yaris HB, new battery and starter. Has 13 volts at battery, not sure where to measure at starter. When I turn the key nothing happens, and when its turned to the off posotion it just about always kicks on the fan. I'm not sure where the relay is as I can't find anything marked so, unless "ST" is it. Before it quit starting completely it had been giving me trouble a few times where it would start after a few false trys.
BobTheYaris is offline   Reply With Quote
Old 09-30-2015, 07:59 PM   #2
Check for a loose or corroded battery terminal. Also, try measuring the battery voltage while turning the key to see if it drops with just the solenoid engaged.
Old 09-30-2015, 08:08 PM   #3
BobTheYaris
the terminals are clean and tight. And the solenoid is not engaging, no noise at all when key is turned.
Old 09-30-2015, 08:15 PM   #4
OK. Do you have an aftermarket alarm or remote starter installed?
If not, check the 30A ST and 15A AM2 fuses in the under hood fuse box.
The ST relay is the one that drives the solenoid and it is part of the integration relay, which is the chunk that the ST fuse is plugged into.
Old 09-30-2015, 08:49 PM   #5
BobTheYaris
The car is a base model so no alarm or anything like that. Both fuses are good and has continuity. I did notice that I couldn't get continuity between any of the st relay terminals but annoyingly theres no diagran to show if it should anyway.
Old 09-30-2015, 08:57 PM   #6
On the ST relay the black wire is the +12 to the coil from the ignition switch, white/black is ground for the coil, white is +12 from the ST fuse, and Violet is the contact output to the starter.
Old 09-30-2015, 09:00 PM   #7
Actually that is the wiring out of the integration relay to the starter. On The ST relay, 1 and 2 are the coil and 3 and 5 are the contacts:
---2
.........|5 |3
---1
Toyota Yaris 2007 car wont crank no start aamrkhan DIY / Maintenance / Service 0 01-19-2015 10:31 AM
KCALB SIRAY - Photo Scavenger Hunt KCALB SIRAY Photo-Video-Media Gallery 5 03-02-2009 10:44 AM
