![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Oct 2013
Due to many factors, I would like to get stiffer rated springs and put them in, along with new struts and shocks.
However, I don't see much available. I remember with my old Caprice's, I would get high performance front springs, and because they only had fronts available, would end up getting Cargo coils in the rear. But, I loves what it did for the handling, that predictable, rear wheel drive, bit loose in the turns, and didn't push unless going in too hard, yada, yada. I don't really want to drop the ride height, nor spend the 2k on the dual adjustable setups. The bars I put on really helped the go cart like handling I have now, but want to kick it up another notch. Anyone know of a spring the same size that would be stiffer / higher spring rates ?
2010 Yaris sedan, TRD CAT back (sport muffler only, really), OBX header (relocated front AF sensor to front pipe), OBX throttle plate spacer, K&N filter (in stock air box-for now), TRD struts and shocks, Mexico Rough Road Springs x 4, new Yota sway bar links front, slotted/drilled rotors and Maxx brakes front, Valvoline synthetic brake fluid, 3M undercoated, 16" Konig Feathers Michelin Pilot Sport AS 3 + Tires TRD rear sway bar, 4 GT Spec bars including: front strut brace 2 point, 4 point ladder brace, mid chassis brace and rear lower tie brace, rear hitch, [B]
| Tein S-tech Springs with Stock shocks combination. | daddz07 | California | 11 | 08-21-2010 01:49 PM |
| Tein S-tech Springs with Stock shocks combination. | daddz07 | Performance Modifications | 1 | 08-09-2010 03:45 PM |
| Bump stop length for drop springs. | PetersRedYaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 19 | 02-17-2010 08:37 AM |
| Another rear spring option! Honda Fit springs!! | kngrsll | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 29 | 10-23-2009 05:02 PM |
