Old 02-05-2016, 01:04 AM   #1
1nz revolution
Drives: 1nzfe
E85 Turbo Build
Walboro 460 lph pump
ID 1400cc injectors
Fuel Lab E85 filter
Fore Inovations E85 regulator
Golden Eagle fuel rail
-10an feed line, -8 return line
Haltech E85 moduel
Haltech P2000 Stand Alone ecu
10.25:1 compression
78mm Pistons
1nz revolution is offline   Reply With Quote
Old 02-06-2016, 09:18 PM   #2
rabbito
rabbito's Avatar
look up my thread E85 Motor Build II..much cheaper build :'D
Sent from my ASUS_Z00AD using Tapatalk
Cosmetic: Toyota red emblem
Old 02-07-2016, 11:00 AM   #3
1nz revolution
Drives: 1nzfe
I hate to break it to you but I have a much better E85 set up than you. Everything about this set up was designed for E85. Full standalone Haltech, ID stainless injectors proper E85 fuel filter and regulator. All you did was swap in stuff not even intended for E85. Think my set up is far superior to yours.
Old 02-07-2016, 12:04 PM   #4
1nz revolution
Drives: 1nzfe
Perfect E85 injectors.
Old 02-08-2016, 08:30 PM   #5
rabbito
rabbito's Avatar
lol...i said cheaper build not better...its only a yaris..stop bragging..
Old 02-07-2016, 02:28 PM   #6
ilikerice
ilikerice's Avatar
Drives: 2010 black yaris
-Derrick-
Old 02-07-2016, 05:38 PM   #7
tmontague
tmontague's Avatar
Hehehe, was thinking the same thing
Old 02-07-2016, 07:17 PM   #8
1nz revolution
Drives: 1nzfe
Wasn't looking for a cheap random parts build. Rather a well thought out build designed for E85 and boost.
Old 02-07-2016, 09:53 PM   #9
ilikerice
ilikerice's Avatar
^this is a better way of saying^
^then this^
It's your choice of words, which is why you have been banned so many times...
Yet, we have never seen a single video of this car running on the street. Your dyno pull videos have yet to see a one of a 400+. All I see are pictures of parts. 5 years, longest build ever
-Derrick-
Old 02-07-2016, 04:38 PM   #10
MedMantle
MedMantle's Avatar
Drives: Yaris '05 1.3 Hatch "R.I.P."
MedMantle is offline   Reply With Quote
my echo turbo build log ipwnr Forced Induction Forum 26 07-14-2015 11:09 AM
Turbo build - stage 1:D abstractmethod Forced Induction Forum 21 03-13-2014 09:04 AM
Want to build costom turbo kit. Need advice from boosted guys! pimp my yaris Forced Induction Forum 639 09-28-2013 12:26 PM
Hyundai Turbo Veloster 150kw *MAD DOG* Off-topic / Other Cars / Everything else Discussions 6 01-10-2012 12:35 AM
