![]() ![]() ![]() Drives: 2005 Toyota Vitz RS Join Date: Jan 2012
Bad weather and slipper road resulted in me crashing my car. Did my best to regain control but only managed to miss a ditch and parked cars. Ended up smashing into a concrete planter box. My first car crash... Bumper is stuffed, internal metal bumpers are stuffed. Some metal hit the belt and tore it so I can't really drive it. Lights are okay but the brackets that keep it in place are stuffed. Any advice on what to look out for when getting repairs done would be appreciated. |
Yours doesn't look that bad. Comparable to mine. You could probably do it all yourself except the paint. Most if not all parts besides the bumper cover, you can get from Rockauto.com
They use your vin to make sure you get the right part too. I took mine to the body shop, only because the insurance paid for it. Are you going to file this as a claim or fix it yourself?
![]() Drives: T1 Join Date: May 2015
Thats Sad.... check to see if your radiator is not damaged and that the engine did not move aswell as your alignment.
![]() ![]() ![]() ![]() ![]() Drives: Scion FRS RS2, ‘21 Crosstrek Join Date: Oct 2008
Looks like mine. Sounds worse. Likely a total loss as mine was for a newer model year.
TRD Upgrades: 18" Wheels wrapped in 215/35/18 PZero's, Sportivo Shocks/Struts, Lowering Springs, Swaybar, Axle-Back Exhaust, Oil Cap, Rad Cap, Signage. Aftermarket Goodies: Piggies SS, K&N Drop-In, Blitz S/C, DC Header, NST Pulley) Toyota Options/Accessories: Sport Pedal Covers, Sport Shift Knob, Ipod Interface, Summer Mats, Winter Mats, Cruise Control, Auto-Dim Mirror, Echo steelies with winter boots.
To drive short distances like maybe to shops for estimates Im thinking the belt will hold up fine. No belt in the pic so I cant see but unless its hanging by a thread if the cars drivable otherwise don't let the belt stop you.
The biggest thing is to stick with OEM parts. I rebuilt two using aftermarket parts (metal and bumper plastics) and was very unhappy with them in comparison to OEM parts.
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
#8 | |
![]() So my litttle beauty Yaris has a non OEM MAF sensor! ![]() Been in there maybe 4 years though.
Unfortunately I only have 3rd party insurance. So I have to fork out for all the repairs. original bumper alone is looking at NZ$900. Going to try and see if I can get the bumper repaired. Its just got a gash, not badly distorted or anything.
Panels all seem okay and I think won't need replacing. The internal metal bumpers will need to be replaced but that shouldn't affect cosmetic. Also looking at getting the light brackets repaired to avoid having to change the entire headlights. Was done on one of my old car's before. Not planning to keep the car for long anyways, might sell him soon. |
if original is too expensive get 2nd hand parts instead of aftermarket...even if the metal bumper is not cosmetic and is being replaced with an aftermarket one, i think it will affect the lining up of the bumper.
#11 | |
Yes will do. I have instructed the body shop to find 2nd hand parts. Here its pretty easy luckily to get used Vitz part as its quite a common car. |
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
TBH, doesnt look too bad. Most if not all can be repaired yourself. The bumper can be reused. Did the rad/condensor get damaged? I'm sure theres probably places that can do repairs at a good price when you live. I'm assuming you need a frame machine or 4 ton frame jack to pull some metal out, seeing that the hood doesnt line up.
An update on whats happened:
I was quite busy with work at the time so I asked my broNlaw to help me out. He knows some body shops and repairers. I told him ask them to do a good job, I dont mind paying bit more, and guaranteed work with a receipt. Got the car back. Looks good from a distance but close up things dont seem to line up. Over the days I have driven, there have been some weird sounds from the engine bay. loud bang sound when going over potholes. ABS light comes on quite frequently. Take it to Toyota to have the ABS looked at and the horror I received: Front rails bent Engine shifted to one side by 20mm water pump damaged and leaking pulley bent wiring has been cut in places lot of codes being thrown up in relation to the ABS. The repair by the body shop has been totally superficial. Underneath the chassis is still damaged, there are bits missing and they've screwed the bumper (filled and painted over) on one side so it cant even be removed now without cutting it. Furthermore they've cut some wires here and there. In short, my car has not bin repaired but its made to look like it has. Next week the body shop gonna get some rage. It's not about the money, I just wanted the car fixed. |
#14 |
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
Wow, I would take them to court so fast. That sucks.
#15 |
I am considering this. I can take them to the small claims court. I think I have a good case especially since I have recently learned that these guys do alot of under table jobs, tax evasion and illegal private jobs.
#16 |
That's a bummer. Sorry you have to deal with that bs. Hopefully it works out in your favor.
#17 |
Yea long story short it didn't quite work out in my favor.
Since family was involved, there are some complications that prevent me from going ahead for trying to pursue the body shop to remedy the situation. Also coupled with the fact it will be a long drawn out process, I've decided to cut my losses. Good news is though I managed to trade it for another car, and considering the amount of damage, I got a good deal. Sadly though, my Vitz days are over :( |
#18 | |
| Tags |
| crash |
| ImportRacer88's Photo Scavenger Hunt | ImportRacer88 | General Yaris / Vitz Discussion | 8 | 02-28-2012 04:19 AM |
| Yaris In Forza 3 | whooppee777 | Off-topic / Other Cars / Everything else Discussions | 61 | 04-03-2010 04:36 PM |
