![]() ![]() Drives: 2007 Yaris Join Date: Aug 2014
Are 13s possible with a 1nZ-Fe
Cold Air Intake
1zz-fe TB 1zz-fe manifold Cams Header full exhaust sticky rubber 80 shot of nitrous direct port im thinking on an ATX you'd still be lucky to break into the 14s, but what about an MTX assuming your a good driver Last edited by crazylegs; 02-16-2016 at 07:44 PM. |
Teal Squealer
yeah that has pistons and rods done does it not. i know you can break into the 12s with a built bottom end and the boost or spray. but i was just curious about the above mod list which might get you 110-120whp N/A and 190-200whp on the bottle. i think that should break into the 13s with an MTX driven by a good driver. the power to weight ratio is there that's for sure. i'm just going to keep it a bone stock daily driver until i have to do something to the bottom end then we will see.
| 1nz Disassembly & Reassembly. | EchoLaQua | Forced Induction Forum | 0 | 06-19-2015 11:17 AM |
| pittsburgh 13's | djhuddy2442 | Tracking, Racing, Auto-X Forum | 0 | 10-29-2014 09:05 AM |
| The Toyota 1NZ Enthusiast's Garage on Facebook | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 3 | 04-07-2014 01:55 PM |
| 1NZ / 2NZ Transmission Compatibility & Aftermarket 2NZ Rods | jtw11 | Performance Modifications | 8 | 09-03-2013 01:49 PM |
| 1NZ port & polish | ChinoCharles | Performance Modifications | 75 | 06-01-2009 06:39 PM |
