Old 02-29-2016, 05:44 PM   #1
emgconsulting
Drives: 2007 Yaris Hatchback
Megan front lower strut bar install ?
Got a Megan front lower stut bar for my 2007 yaris hatchback, everything I read seems to be a simple install so I purchased one. As recommended after using a breaker bar to loosen and used an air wrench to spin out the bolt. The bolt comes out about 3 1/2 inches and then just spins I tried reinstalling and loosening again and putting downward pressure to no avail. I cannot see the other end where this bolt goes up into the chassis. Anyone have any ideas? or done this?
Thanks
After lifting up the carpet and confirming no nuts, used small sledgehammer hitting a vise grip, after lots of rust, bolt fell out.
DONE, let you know if I feel any difference.
emgconsulting is offline   Reply With Quote
Need input on ULTRA RACING 23MM SWAY BAR VS NITTO REAR LOWER STRUT BRACE. marcus Wheels, Tires and Suspension Forum sponsored by The Tire Rack 18 02-22-2011 07:32 PM
front sway bar install birdman DIY / Maintenance / Service 5 10-04-2009 08:41 AM
