Free: Half set used OEM Brake Pads.
GONE
Did a brake job on someone's '07 Yaris and now have two good pads left. They are used but have more than half their life left. If anyone is doing a brake job and need two good pads just pay shipping or can pick them up free. These are genuine Toyota pads. Last edited by Bluevitz-rs; 07-30-2016 at 11:50 PM. Reason: Gone |
lol ...I must have a bin full of outside pads from doing brake jobs on Yaris , never will run out for myself haha
Typical problem with yaris it kills the inside pads if one does not drive the crap out of there car . |
That's exactly what it was. The one inside on the driver was metal to metal. They were only there so I could assess what they needed and I had to drive them home because I couldn't let them leave LOL.
Is it typical to go +65k on the original brakes? I'm up over 65k miles on my car now and they keep telling me my brakes are good. I don't recall going that long on original brakes in the few other cars I've owned.
What I thought I'd do was
Drives: 09 Yaris Sedan Join Date: Aug 2009
I had 87k on mine when I changed the brake pads. The outside ones were fine but the insides were getting thin. I probably could have gotten another 20k out of them but both of my rotors were warped and it was driving me crazy.
![]() My Nissan Hardbody (D21) 4x4 build log Check out my YouTube channel (mostly shooting) - http://www.youtube.com/user/47MasoN47 |
#6 | |
But I find if ur hard on ur brakes this issue is not as common. Sent from my ONE A2005 using Tapatalk |
#7 | |
#8 | |
Did my rear shoes for the first time this year at 275,555 kms. Lots of meat left on the bottom of shoes, tops where gone. On my 4th set of front pads.
#10 | |
#11 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
also, car was driven in the mountains it's entire life. lots of brake use.... |
#12 | |
I got about 1 mm left in the rear have new shoes in my tool box lol just lazy to replace. Sent from my ONEPLUS A3000 using Tapatalk |
![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Sep 2010
Shoes wear out just like pads, just not as quickly. They typically last twice as long. The only way what you are saying is even possible (and would not likely ever happen) is if both wheel cylinders were completely siezed and not applying the shoes anymore.
05' Echo Hatch - Greddy Supercharger - rear disc |
#14 |
![]() ![]() ![]() ![]() Drives: 2010 Yaris Sedan Join Date: Feb 2010
I replaced my fronts at 97000 miles. Still had a surprising amount of pad left, both inner and outer pads.
#15 |
![]() ![]() ![]() Drives: Yaris Hatchieback Join Date: Jun 2010
brake pad replacement
i had mine replace all around front pad, rotors and rear shoes in 100500 miles. my tech said still have 1/4 inch life to go. i had replace stop tech brake line since 35k.
#16 |
![]() Drives: 2009 Yaris Join Date: Dec 2008
Original breaks with plenty of life left in them on my 09 HB, at 154K miles.
Most of the mileage was long distance highway driving (I had a 180 mile round trip commute to work each day)- so you really can't wear out what you don't use. |
#17 | |
![]() Drives: 2007 Toyota Yaris Join Date: Jul 2014
#18 |
^ Courtice
