Old 05-22-2016, 11:22 AM   #1
mik23
Drives: yaris 2005
Air Conditioning Sight Glass i Location pls !
Hi All
Can anyone guide where sight glass for airconditioning system to check the refrigrent is located.
mik23 is offline   Reply With Quote
Old 05-22-2016, 11:26 AM   #2
tmontague
tmontague's Avatar
If you are looking into the engine bay it is near the front left (passenger side) and located on the hard metal a/c line. It is a small circle window.
Fwiw, i've never had been able to match up exactly with what the manual says I should see. I just see some clear fluid in there and a small bubble.
My a/c has always worked fine. Imo the trick is to run the compressor every week or so to circulate the oil in the system
Old 05-22-2016, 11:32 AM   #3
mik23
Drives: yaris 2005
my eye sight is worst than i thought can you post a photo pls
Old 05-22-2016, 06:12 PM   #4
Pictured within the red circle from left to right are:
Pressure sensor
Sight glass
High pressure schrader valve
Need help troubleshooting air conditioning davislau DIY / Maintenance / Service 7 07-15-2015 10:54 AM
Air conditioning filter Geelmeel DIY / Maintenance / Service 41 10-31-2010 09:02 PM
Liftback Air Conditioning (Cabin) Filter info Snappy DIY / Maintenance / Service 24 10-01-2010 06:36 PM
air conditioning markpeppie General Yaris / Vitz Discussion 34 06-20-2006 01:17 PM
