![]() Drives: yaris Join Date: Mar 2015
ABS !!!
good morning,
yesterday i get the abs light come up on my yaris (1999-2005), so i have connect pin 4 and 13 to read the error code. i have find code 38 (right rear sensor). i unplug and plug the sensor cable and the light come down. i have tested the abs system in road it was fine all work correctly. after 15 min i have put the key in position "on" and i have not get the light on of abs !!! i have retest on road and no abs system working (wheel blocked) !!!! i have unplug the cable of sensor to see if the light come on but any way the is no light ! why the ABS is totally H.S ? can you help me please. REGARDS Last edited by wassimusa; 05-31-2016 at 05:19 AM. |
Problem resolved
![]() ![]() ![]() Drives: 07 HB YARIS, 15 JUKE, 00 TUNDR Join Date: Mar 2007
How did you fix it? What was the issue?
Project so far: 2zrfe swap, Megan racing coilovers, TRD rear sway bar, whiteline bushings, RPM long tube header, midpipe, and DC sports xD exhaust, brake upgrade in front, MI stainless braided lines all around, matte paintjob, Takada cold air intake, various gauges, rear seat and belts removed. Future: Turbo. |
| Abs and slip indicator on need help speed sensor | Jeffbass | DIY / Maintenance / Service | 0 | 04-28-2016 01:38 PM |
| FRONT ABS | htschek | DIY / Maintenance / Service | 1 | 08-05-2013 09:14 PM |
| ABS brakes / Would you buy a Yaris without them? | 3cyltrbo | General Yaris / Vitz Discussion | 66 | 03-26-2011 08:21 PM |
| What's with ABS? | jgag123 | Canada | 9 | 01-01-2009 06:04 PM |
