![]() Drives: Yaris 5 speed Join Date: Feb 2016
Low Idle fixed!
Well, I just bought the Yaris with 65K miles. Once the car is at operating temp the idle seems to drop a little too low for my taste, the low idle caused some vibration what appears to be soft engine mounts, a low freq vibration enough to be annoyed.
So I changed out the plugs that didn't do it, but after cleaned the MAF and replaced the air filter, the low idle problem is now gone. Using my phone Torque App I was able to see a 40 RPM increased at idle, the car idles nice and smooth now at 600 RPM. Wish I had performed the above 2 tasks one at a time, but doesn't matter they both makes sense for the increase of RPM anyway. Just wanted to put here for future purposes, and thank you for reading. Cheers!!!!!!!! |
![]() ![]() ![]() Drives: 2007 red Yaris HB AT Join Date: Dec 2013
cool, i have that problem in another car (RAV4), especially with AC on. it's due for air filter change. will see if that helps.
| Low idle speed after battery disconnected | YarisTR-VVT | DIY / Maintenance / Service | 3 | 12-08-2015 07:20 PM |
| Fix For Low Idle When Warm On A Yaris Mk1 | danielbb | DIY / Maintenance / Service | 0 | 06-12-2014 04:13 PM |
| Help with low idle from Venezuela | Yarisvene | DIY / Maintenance / Service | 5 | 06-23-2007 08:23 AM |
| Low idle speed | gonzo452001 | DIY / Maintenance / Service | 9 | 02-21-2007 08:41 PM |
