![]() ![]() ![]() ![]() ![]() ![]() Drives: 08 Yaris sedan auto / Fit auto Join Date: Oct 2009
Top tier gas : Healthier for your car ...
I always fill up w/ either Shell or Esso. A few months ago I tried gas at a Husky that was 9 cents cheaper/liter and I got about 100km less on my tank under comparable driving. Never again.
Apparently up here Esso and Shell are top tier gas
#3 | |
![]() ![]() ![]() ![]() ![]() ![]() ![]() Drives: 06 Polar White 5dr, 13 Soul 4u Join Date: Oct 2008
Shell - Winston/Argentia 7 Eleven - Georgetown Husky - 401 near London Along with various Pioneer, Esso, Costco and many others, I've not experienced any real noticeable difference in mpg. I do stay away from non-branded stations unless absolutely necessary.
![]() ![]() ![]() ![]() Drives: 2005 Toyota Echo Join Date: Aug 2010
I used to get the same mileage on Husky 87 as any other 87 octane gas when I still had my Echo, and I get the same mileage on Husky 91 as I do on any other 91 or 94 octane gas on my current car. Even the 91 from the truck stop Husky by 401/Dixie.
2006 Saturn Ion Redline 2005 Toyota Echo RS 4dr hatch - Cyl #3 bad - sold 2000 Toyota Echo 2dr coupe - The track car - rusty & scrapped |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
Here in Montreal i see no signs on gas stations proclaiming they provide this top tier gasoline.Odd that this top tier gasoline being highly touted as superior to ordinary gasoline that they wouldnt advertise the fact that they are a designated provider of this super deluxe top tier gasoline.
![]() I have no brand loyalty and just fill my car with gas at whatever gas station is convenient when i need gas.
Have Yaris will travel.. Last edited by jambo101; 07-22-2016 at 12:13 PM. |
#6 | |
![]() ![]() ![]() ![]() ![]() Drives: '15 Yaris SE 5MT Join Date: Jun 2014
![]() ![]() Drives: 2010 Yaris hatch Join Date: Mar 2011
For me, it's not the mpg issue. It's a well-known issue on Yari that if you use a lower-tier gas (no name gas, or some cheap brand), there won't be enough cleaning additives in the fuel to keep the sender clean, and you'll end up with a gas gauge that doesn't function properly. I use either Chevron or Shell, and if I HAVE to use a lower gas, I make sure I top up with good gas after.
"I like the dreams of the future better than the history of the past" - Patrick Henry |
Definitely you don't want cheap gas in your car or there will be problems!
I'm running She'll now. Wife uses Valero.
We too use VALERO , the 91 w/o E . The 89 is E5 and the 87 E10 . The 91 is at a reasonable price for now . Not many non E or Top Tier or both for carriers in the region .
![]() Drives: 2017 iA Join Date: Sep 2017
I didn't know no real gas (not E5 or E10 ethanol blend) was available in California. How do I confirm and who else is selling non-Ethanol gas?
Octane rating numbers--which system on USA pump buttons?
USA/Canada 2007 Yaris owners manual: "Fuel Type: UNLEADED gasoline, Octane Rating 87 (Research Octane Number 91) or higher."
Pump buttons are 87, 89 and 93. Unlabeled. Octane rating numbers--which system on USA pump buttons? "Top tier" does not appear in manual. Is it thread drift or is their any connection...does top tier have anything to do with octane rating? |
The TOP TIER report is originally from A.A.A. and more detailed . May want to take a look at it . http://newsroom.aaa.com/2016/07/aaa-...created-equal/
![]() ![]() ![]() Drives: 2011 3dr LB Polar White Join Date: Apr 2011
I'm disappointed to see Sam's Club gas isn't listed as top tier. However, Costco is on its way in our area. Can't happen soon enough. Not a Walmart fan.
#14 |
Here's the original 34 page results of TOP TIER gas from A.A.A. https://s3.amazonaws.com/association...rt-FINAL-1.pdf .
#15 |
![]() ![]() ![]() ![]() Drives: Yaris Sedan 5MT Join Date: Oct 2008
Been doing Costco for the most part lately.
#16 |
![]() ![]() Drives: 2010 Yaris Join Date: Jan 2010
A list of top tier retailers can be found here
http://www.toptiergas.com/retailers/ I only use top tier fuels in my vehicles, in fact, my 2013 Hyundai Sonata actually specifies that top tier fuel should be used (its in the owners manual).
The moving power of mathematical invention is not reasoning but imagination. Augustus de Morgan Truth does not change because it is, or is not, believed by a majority of the people. Giordano Bruno |
#17 | |
#18 |
One of the numerous pitfalls of buying a used vehicle, without a very in-depth inspection of the subsystems, is that you usually don't know what type of gas the previous owner(s) might have used.
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 03:47 PM |
| Fuel Economy | swng | Fuel Economy Forum | 2089 | 01-23-2015 07:41 PM |
| DIY - Removing the gas tank from under the car (to access the fuel filter, etc.) | CTScott | DIY / Maintenance / Service | 1 | 08-21-2013 04:57 PM |
| How to save on $4 a gallon gas this summer | fnkngrv | Off-topic / Other Cars / Everything else Discussions | 1 | 05-26-2011 08:07 PM |
| New car shopping - long post | littlecarlove | General Yaris / Vitz Discussion | 19 | 11-01-2006 11:58 PM |
