Old 08-22-2016, 02:37 AM   #1
AndreS123
Drives: 2012 Yaris L, 2017 Yaris L
rear axle beam compatitbility?
I have a 2012 L model hatch, recently hit curb pretty hard and bent the rear axle beam slightly(got the wheel & hub too).... anyway, looking around I see car-part lists one beam assembly for 2nd gen and one for 3rd gen as different parts. not planing on a SE disc brake upgrade, even though it would be the time, since they are different. I can find a local 2nd gen beam for $250(maybe less), but a 3rd gen is $400.
does anyone know the details on the differences? just on the axle beam. or are there any other models using the same beam?
AndreS123 is offline   Reply With Quote
Old 08-25-2016, 11:43 AM   #2
texascolt45
Drives: 2015 yaris
just look at an OEM online parts catalogue or have the wrecking yard look in the Hollander book and see what crosses.i bet theres a lot that work.
texascolt45 is offline   Reply With Quote
Old 08-25-2016, 11:48 AM   #3
texascolt45
Drives: 2015 yaris
looks like they all have different numbers.french built,2010,2015.you might be screwed.
Old 08-25-2016, 04:23 PM   #4
kimona
kimona's Avatar
Drives: 2014 White VITZ
Can't comment on the compatibility of rear axle beams; however, I do know that some OEM parts for French vs. Japanese built cars have different part numbers (and prices), but are identical parts.
Solved: Clunk in Rear Suspension (2008 Yaris 3-door) Redbat01 DIY / Maintenance / Service 2 02-10-2015 12:33 PM
Yaris SE 2012+ Rear axle on 2011 and earlier ? Drum/Disc Solution ? jenfre Performance Modifications 2 02-04-2015 07:13 PM
Newly refreshed 2011 Toyota Corolla Kal-El Off-topic / Other Cars / Everything else Discussions 23 11-27-2010 12:57 PM
