Old 08-22-2016, 08:48 PM   #1
David C
Drives: White '07 3dr LB
Uninterrupted power to stereo during startup ?
I'd like to find a way for the head unit not to shutdown when starting the car, so when I play music from my USB drive, I'm not out of music for 20 seconds every time I turn my engine back on at red lights/traffic jams.
I have an aftermarket Kenwood Excelon and also a powered sub (SSL LoPro 8) that is remotely powered when the radio turns on, so that would also have to stay on.
The ignition wire only powers when he key is in, what about the power wire ? Does it also shut off during startup and if so, any easy way to bypass it or am I on my own from there ?
Old 08-22-2016, 09:12 PM   #2
bassmannate
Drives: 2008 Toyota Yaris
You COULD run your accessory wire (red) to an ignition wire and cut it from the accessory at the factory harness.
I wouldn't do it though. The point of putting accessories on a separate circuit is to reduce strain on the electrical system during start. I do get it though. Kenwood stereos take forever to boot.
Sent from my LG-H811 using Tapatalk
bassmannate is offline   Reply With Quote
Old 08-22-2016, 09:21 PM   #3
The ACC cut relay pulls power from the radio and power outlet when the starter is cranking. You can bypass the relay by pulling it (brown relay in socket attached to left side of under dash fuse panel) and jumping the center top terminal to the bottom most terminal of the socket.
Old 08-22-2016, 09:32 PM   #4
David C
I'd do that and add a switch, so in the winter I can undo the bypass during cold starts.
Second question : When using the climate control dial, on a 2007 HB, when set to colder, and the fan on (anywhere from 1 to 4), but without the AC button actuated, is there any power being consumed to try to keep the air as cold as possible ? Or does the AC only starts when the AC button is being used ?
Old 08-22-2016, 09:31 PM   #5
SirDigby
Drives: 2007 yaris 3 door
hahaha! that'll work!^^^^
Old 08-22-2016, 09:35 PM   #6
bassmannate
You'll have some load on the alternator to run the fan but nothing like the compressor would if you had the AC on.
Old 08-23-2016, 09:45 PM   #7
David C
So I did bypass the ACC cut relay and the voltage drop is too much to keep the stereo from rebooting, so I'll have to add a capacitor to that 7.5a ACC circuit to make it work.
kuro-kuro, mga sarisaring katanungan xtremist Middle East 2740 01-27-2020 03:36 AM
Stereo Upgrades....what to do!? gravylegs In Car Entertainment + Electronics (audio / video / alarm) 39 02-28-2010 12:58 PM
Power Enterprise Super Charger Kit Round 2 $3100 Power Enterprise Evan Forced Induction Forum 312 03-26-2009 06:48 PM
Power wire gauge vs stereo wattage goku87 In Car Entertainment + Electronics (audio / video / alarm) 1 02-24-2009 02:16 PM
