Old 08-31-2016, 09:30 AM   #1
gumby002
Drives: 2008 Yaris Hatchback
Belt Squeeling like a Mofo
Hello
My belt squeals.
Here is what my observations are:
-Replaced Water pump & belt a few years ago
-Replaced Alternator 2 months ago
- Belt squeals when AC is on - I live in FL...AC button is always on
- With the hood up, I can see that the belt, when squealing, is not moving.
- Belt does not squeal when the AC light is off most of the time. If it does, its for 2-3 seconds only.
- AC does blow cold air, really cold, but it takes a minute or so of the squealing and then not squealing for the air to get cold
I am thinking that its the AC unit that is causing this. Its an uneducated guess because I've replaced 2 of the 4 pulleys/sheaves already.
Thoughts? Things I should try? Am i on the right track?
Thanks!
James
gumby002 is offline   Reply With Quote
Old 08-31-2016, 09:36 AM   #2
Simple question first since it is not listed above. Have you replaced the belt? Could be getting extremely glazed if you have not.
Old 08-31-2016, 09:43 AM   #3
gumby002
yeah, forgot to add that. The belt was replaced when the water pump was replaced
And I've sprayed the belt with belt dressing when the squealing really got bad thinking that maybe the belt wasnt gripping the new alternator sheave.
Old 08-31-2016, 12:25 PM   #4
bronsin
bronsin's Avatar
I would loosen the belt so I could turn the pulleys by hand. Perhaps one of them isn't freely turning?
Good luck!
Old 08-31-2016, 12:57 PM   #5
dogsridewith
Drives: 2007 2-door hatchback
serpentine belt tension Yaris
simpler question--did you check and/or raise belt tension?
Old 09-10-2016, 01:45 PM   #6
MUSKOKA800
MUSKOKA800's Avatar
I had good luck with Gates belts when running my previous Yaris with the Blitz S/C.
My current stock Yaris needed a belt and I put on a Continental belt. It seems to stretch constantly. Every month it will start squealing at start up with the AC on. Switch of the a/c and it stops and fine later once warmed. I need to tighten it monthly to resolve this issue. Reference marks I put on the alternator arm each time show that it's the belt growing, not slipping adjustment. No more Continental belts in the future for this guy!
Old 09-10-2016, 04:47 PM   #7
dogsridewith
Yaris serpentine belt tension adjustment match mark
Belt on new-to-me 2007 seemed so tight I match-marked the setting and loosened it some. Still no squeal.
MUSKOKA800's keeping it at incipient squeal will be best for various accessory bearings...one of those owner-mechanic advantages, where the shop has to overtighten to deal with the stretch.
Old 09-10-2016, 05:38 PM   #8
MUSKOKA800
MUSKOKA800's Avatar
Yes, I just keep adjusting it about 1/8th inch at a time. Just enough to silence it. Certainly don't want to trash the alternator or water pump bearings due to extreme belt tension.
Belt Tensioner for the Yaris fmicle DIY / Maintenance / Service 25 11-26-2022 11:37 PM
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 07:32 AM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Squealing Belt rossman DIY / Maintenance / Service 8 01-31-2012 01:58 PM
The Accessory belt? N9QGS DIY / Maintenance / Service 4 02-12-2009 11:05 PM
