![]() ![]() ![]() Drives: 2012 Toyota Yaris Sedan (Vios) Join Date: Dec 2015
whats your normal running temperature for your yaris?
mines running 86~90 all the time..no higher than 90 on my engine temp. gauge...i am running E85...
i live in thailand, temperature here is 40c/104f with heavy humidity what about yours? Sent from my SM-J700F using Tapatalk
Brain: ATD E85 Timing Advance ECU Engine: 1JZ Injectors, Header, Center Pipe, K&N Drop In, E85 Injector Converter Suspension: Hankook Tires, Performance OEM replacement Shocks & Springs F: 1.5 B: 1.4, Mu Spec brake pads, Front tower & Rear sway bars, Rays nut & lock Electric: Volt Stablizer & Multi gauge obd2 Cosmetic: Toyota red emblem
![]() ![]() Drives: 2014 Icon+ 1.33l Multidrive Join Date: Nov 2010
I don't know, it doesn't have a coolant temperature gauge.
I presume it's alright because the low temp warning goes out and the red high temp warning doesn't come on. |
![]() ![]() ![]() ![]() ![]() Drives: yaris 08 sedan Join Date: Oct 2008
My scan gauge reads 184-186 degrees at operating temp.
Have Yaris will travel.. |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
That sounds normal, and pretty good for such high temps. Humidity actually helps the radiator work more efficiently.
Tweaker
Drives: 2009 Yaris Sedan Join Date: May 2017
87*c or 188 F on the scangauge. Not enough for winter time at minus 25 C , it would need to be at 95C or 203F to be able to heat up the inside as it should be.
No-idea degrees
182-184 (83-84) always at driving speed.
Normal operating temperature, 90 degrees C using my scan tool
| 2012 Yaris at SEMA | Jason@SportsCar | Third Gen Yaris General Discussion | 5 | 09-23-2013 03:55 AM |
| Yaris vs Celica | jesh462 | New YARIS Purchase Forum | 11 | 10-18-2012 11:49 PM |
| Consumer Reports Is On Crack!!! | doublewam | General Yaris / Vitz Discussion | 82 | 05-07-2011 11:03 AM |
