![]() ![]() Drives: 2015 yaris Join Date: Aug 2015
seat belt chime
anybody know the way to turn off the seat belt chime on a 2015?i know how on my 09 Tacoma but it doesn't work the same on my Yaris.
![]() Drives: lowered/ exhaust Join Date: Apr 2016
seat belt chime
You have to use techstream to do it
easy, fasten the seatbelt.
Nice
Well one reason is what if you have a heavy object on the pass front seat and it's setting off the seat belt chime. And you'd rather have the chime to be off so you don't have to "buckle" up the object that's not a person
Pull the seat belt behind the seat and latch it. Or go to the auto wreckers and cut off a buckle from a used car and use it that. The solutions are pretty simple.
![]() ![]() ![]() ![]() Drives: 2011 Scion tC Join Date: Jul 2012
#10 | |
But honestly if u really need it off take it to Toyota it will take less than 10 min with techstream, it can be easily switched off.. I have done it in my Yaris for when I drive through drive thru and need to remove belt to get to my wallet. So go visit ur nearest Toyota dealership Sent from my Nexus 6P using Tapatalk |
![]() ![]() Drives: Yaris 1.33 vvti 2015 Join Date: Nov 2014
my Toyota dealer said no.is there some cloned techstream software I can load on my tablet to fix it and other stuff on my Tacoma too.
| DIY - Replacing the Front Seat Cushions | CTScott | DIY / Maintenance / Service | 6 | 10-04-2016 06:39 PM |
| seat belt chime disable? | Lewis | DIY / Maintenance / Service | 19 | 05-25-2012 04:36 PM |
| Clazzio Seat Cover DIY Install | PETERPOOP | DIY / Maintenance / Service | 31 | 09-10-2010 03:30 PM |
| Seat belt swap | N2scouting | DIY / Maintenance / Service | 0 | 07-31-2009 12:51 PM |
| Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
