Old 11-29-2016, 10:23 PM   #1
SirDigby
Drives: 2007 yaris 3 door
shiny for 10 minutes
I bought a weaponR exhaust manifold. it was shinny. I only got to look at it for about 10 minutes.
now it's not shinny anymore :(
unshinified
Old 11-29-2016, 11:12 PM   #2
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
Yeah but header wrap makes it look legit!
Old 11-30-2016, 08:57 PM   #3
SirDigby
it also helps with flow and scavenging. plus, that computer being 6 inches from the manifold scares me...
Old 11-30-2016, 10:51 PM   #4
invader166
Pumpman
Drives: 2019 Kia Soul EV Base
You have great taste sir.
Personally I think you went a bit over the top with the wrap, but it does look very nice.
I've been running mine for nearly 2 years with no wrap or heat shield, and never ran into any problems.
Old 12-02-2016, 12:23 AM   #5
SirDigby
tri Y makes for better low end torque. :) I didn't by the DC one because i'm not looking for top speed. I am looking to go quickly....
and the wrap helps on any engine. higher temperatures (to an extent) creates higher pressure/flow, which creates better scavenging from sister cylinder, which is exploited by the try Y pipe. (as the theory goes)
Old 12-04-2016, 01:56 PM   #6
JessMess
Drives: 08 Yaris hatch back
Sweet looks awsome
JessMess is offline   Reply With Quote
Old 01-25-2017, 04:17 AM   #7
ncp13
ncp13's Avatar
Drives: 01 Yaris TS
Looks good, how does it perform? (butt dyno ?)
I have a spare stock manifold.. I should wrap it for educational purposes
ncp13 is offline   Reply With Quote
Old 01-25-2017, 09:10 PM   #8
SirDigby
i have not installed it yet. need to buy the rest of the parts. (resonator and muffler) then i'll go get it all plumbed up. waiting till do my taxes
Old 01-25-2017, 09:55 AM   #9
malibuguy
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan
be sure to port-match the header to the gasket. There is some shrouding on them. Plus while your at it, investigate the inner joints & blend as necessary. Mine had some really rough joints
-Greg...the Exhaust Freak.
-82 Malibu, 1uzfe swap
-97 Tercel coupe, 1nzfe/4.31
-96 Tercel 4dr
Old 01-25-2017, 12:48 PM   #10
Elwe2k
XP10 Enthusiast
Elwe2k's Avatar
Drives: 2000 Echo Coupe
That looks awesome! Now I want one
I always wondered if this Yaris parts fit in a 1st gen US-Spec Echo. It's the same engine though.
'01 Yaris 5dr Hatchback M/T | Blue Streak Metallic [RIP]
'00 Echo Coupe A/T | Absolutely Red [Still Alive]
Elwe2k is offline   Reply With Quote
Old 01-25-2017, 06:08 PM   #11
malibuguy
Obsessed with 1.5L
^ outlet flange bolt pattern is wider for the yaris and the outlet is in a slightly different position. You can probably use one...just modification to your front pipe will be needed.
-96 Tercel 4dr
Old 01-26-2017, 12:04 AM   #12
Elwe2k
XP10 Enthusiast
Elwe2k's Avatar
You mean like replace the bolt pattern with another aftermarket pipe? or maybe adapt the OEM outlet flange? I was thinking about adding a aftermarket pipe and/or exhaust from newer models and customise to fit....
exhaust manifold, exhaust wrap, weapon r, weapon-r
Yaris dead then minutes later starts fine vinny121 DIY / Maintenance / Service 6 02-27-2015 08:01 PM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 10:41 AM
Shiny glass-looking plastic flakes from HVAC, and windshield LugNut New YARIS Purchase Forum 15 11-20-2011 10:39 AM
