![]() ![]() Drives: 47 2013 yaris l hatchbacks Join Date: Nov 2016
Loose rear view mirror
So my 2013 Toyota Yaris rear view mirror seems loose. When you're going down the road it's kind of bouncing. I found it annoying enough to try to look at it and see if I can fix it. Upon inspection I found it to be an extremely easy fix. I thought I'd post this see if anybody else is having the same problem. It's literally less than a one minute fix.
1. Pull up on the rear view mirror assembly towards the headliner this will disengage the rear view mirror from the lug on the windshield. ![]() 2. Bend the tips on the metal clip on the mirror mount inwords. I used my ignition key. ![]() 3. Slide the mirror mount back on the lug on the windshield. Problem solved!! Hope this can help. Sent from my SAMSUNG-SM-N900A using Tapatalk |
Nice
![]() ![]() ![]() ![]() ![]() ![]() Drives: 2008 Yaris Liftback (Sprocket) Join Date: Oct 2008
You're lucky, many times it's the cheap plastic ears that bend/break, making the mirror assembly useless...
#4 | |
#5 | |
![]() ![]() ![]() Drives: Vitz RS Join Date: Feb 2009
I had to put silicone behind my mirror as it never stayed where I put it. Amy small vibration or on really hot days while the car idles the mirror would just drop. Will try this when someone decides to move the mirror making the silicone useless.
Sent from my SM-G920V using Tapatalk |
| Temp guage and compass in Rear view mirror | Chaad32 | Cosmetic Modifications (Exterior/Interior) | 10 | 10-30-2020 07:47 PM |
| Yaris 2011 3rd gen rear view camera problem | robertkk | In Car Entertainment + Electronics (audio / video / alarm) | 2 | 06-19-2014 08:56 PM |
| Newly refreshed 2011 Toyota Corolla | Kal-El | Off-topic / Other Cars / Everything else Discussions | 23 | 11-27-2010 12:57 PM |
