![]() ![]() Drives: 09 5MT Join Date: Oct 2008
Musty smell when heat first turned on.
Hi all,
Searched, and I found a few threads regarding this. I have checked for blockage in the AC drain tube (none), and there is a cabin filter installed. If I have heat on, eventually, the windows will fog up, and if I put on defog, the musty smell first occurs. This obviously sounds like water somewhere in the system, but I don't know what else to check, other than ripping the dashboard apart und dismantling the AC. Before I do this, anyone have suggestions on how to troubleshoot/pinpoint the problem besides what I have tried? Model is 2009 4DSD 5MT. Thanks in advance...Eric |
It's because you're using the A/C when the defrost setting is used. So it takes moisture out of the air but after years of use there can be an accumulation of dust on the evaporation coil that never dries out and gets moldy. The only way to avoid the smell is to avoid using any defrost setting. Even the mixed mode uses A/C.
I know on my Echo the setting for floor only still put air up on the windshield so I never use any defrost settings. |
#3 | |
Hubcap Enthusiast
Drives: '09 3-door 5-speed Join Date: Jan 2016
#4 | |
![]() ![]() ![]() ![]() ![]() Drives: 2007 yaris 3 door Join Date: Sep 2015
I'm surprised you have not noticed the rpm's all over the place when idling with defrost on... it sound so horrible |
^^ yes.
Yes, it definitely turns on the compressor when in defrost or mix defrost/floor.
Don't know how you can live without it in Ontario, but I'm glad that works for you. Doing a little more reading, and I saw that this can be a problem in recirculation mode. I said to myself "I never put the settings on recirculation mode". But I'm not the only one driving the car. lo and behold, that's what is was set on. I don't know how long it's been on that setting, but next drive I'm going to make sure it's fresh air mode and blast the heat, and see if that will dry out things. Thanks for the quick replies. Eric |
musty smell HVAC service advisory
Not a recall notice, but isn't there at least one thread discussing Toyota service advisory for musty smell in the HVAC of some Yaris? Discussion there of whether offending component is accessible without complete disassembly of the automobile? (Mind of Toyota)
Toyota likely added this feature (as do other manufacturers) to increase the life of the a/c compressor. Almost all the Toyota's I know that are going on 11, 12 and 13 years of life still have their fully functioning a/c system thanks to this feature of running the compressor when the defroster is on.
Most people won't turn on their a/c for months and even years. The a/c compressor periodically needs the refrigerant cycled through it so that the oil gets cycles through it and stops the compressor from seizing. Most people have no idea and won't touch their a/c button unless they need it and then complain that their a/c went to crap within 5 or so years. It also reduces the amount of time it takes to defrost a window by quite a bit. if you decide to override this feature just make sure you hit the a/c button for 10 mins or so every couple weeks. Your a/c system will thank you. As for the OP's question, try turning on the fan to full and just below your windshield outside of your car spray a mixture of water and vinegar or water and hydrogen peroxide into the vents. This may be enough to clear out some of the crap on the evaporator. or try what CTScott recommended in another post and squirt some water mixed with bleech up the rubber drain hose
Thanks mush for the idea...will give it a shot.
Would you also believe that on another thread there was mention of running the ac with the "fresh Air Mode" on, instead of "Recirculation Mode". Of course, I told myself "that can't be it, since I never switch to use the recirc, I always use fresh. It was in recirc mode...I feel like an idiot. I have since switched it to fresh, and will get the car up to operating temp and blast the heat, just to see how that works. I will also try tmontague's idea, if the musty smell remains. Thanks all...Eric |
| Mga Bagong Kayaris ! ! ! | syntax | Middle East | 749 | 04-26-2021 02:40 AM |
| Burnt smell in cabin at high speed in cold weather | grilled cheeseus | DIY / Maintenance / Service | 13 | 12-15-2018 07:29 PM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 09:08 PM |
| Coolant Smell after sitting in hot sun? | Snappy | General Yaris / Vitz Discussion | 3 | 05-31-2009 12:18 AM |
