![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Strut problem?
I have 2 new kyb struts in front of me ready to go on.
I got tire off and see the rubber bellow is torn. I talked to KYN directly and they said there is a piece that needs to be cut out and reused or put new one in. It seperates metal on metal contact. I was going to get these but he said it may not work. https://www.autopartsway.ca/partdeta...n-strut-bumper Does anyone here changed strut on 2007 yaris Hb 2 DR. I am confused as to what this plastic piece is that he says needs to be cut and reused or buy another as its part of the strut assembly. From what he described its a hard plastic piece connected to the bellow. I do not believe he is talking about the plastic piece that goes between shock and round metal cups on top/bottom of strut. Here are the struts that I have https://www.autopartsway.ca/partdeta...strut-assembly UPDATE: I see what he means by the bellow http://i.imgur.com/oIO13OE.jpg Cant seem to find this exact bellow though as its different then the one I linked above Last edited by Pinchlite; 02-27-2017 at 05:23 PM. |
It sounds like they're talking about the bump stop. I had to cut mine 1.4 inches when installing my Tein springs to make room for the additional strut travel. Something like this:
https://www.walmart.com/ip/42934657?...&wl13=&veh=sem Last edited by ern-diz; 02-27-2017 at 05:23 PM. Reason: To add image. |
#3 | |
bellow
I realize i need to cit 1.5 off the bump stops as my springs are 1.5 drop. I took a look at my strut closer and need a special boot/bellow that has flange ontop that sits ontop of spring. Looks like I need to track this down. http://i.imgur.com/AMLdd2z.jpg Looks like I found a work around. I can use the stock boot and cut the ripped part out.Then use these bellows underneath. https://www.autopartsway.ca/partdeta.../pagenum1/tabs http://i.imgur.com/oroZaGk.png http://i.imgur.com/gXWAzKN.png Last edited by Pinchlite; 02-27-2017 at 06:28 PM. |
Ah, gotcha.
Bellow.
| DIY: Rear shock, sway bar, and strut brace refit | Tapokata | DIY / Maintenance / Service | 19 | 05-31-2016 02:05 AM |
| Unique Smell from Air Going Through AC Blower | EddieCabael | DIY / Maintenance / Service | 30 | 01-19-2015 10:08 PM |
| Rear hatch strut problem | MiSFiTx87 | DIY / Maintenance / Service | 10 | 08-29-2014 12:15 PM |
| A day out with mechanic went wrong- Right arm problem | talhahs | DIY / Maintenance / Service | 6 | 05-17-2013 06:20 PM |
| Service Problem | Lizardboy | DIY / Maintenance / Service | 19 | 10-06-2006 10:12 PM |
