Old 05-17-2017, 02:42 PM   #1
pribek
Drives: Man
Send a message via ICQ to pribek Send a message via AIM to pribek Send a message via Yahoo to pribek
Toyota Yaris Hybrid AT 2016 OBD2 compliant
Does the Toyota Yaris Hybrid AT 2016 "European Version" have an OBD2 compatible connector?
I wonder because Scangauge works without any problems.
HUD (Head up display) does not receive OBD data "OBD-compatible"
Greeting
pribek is offline   Reply With Quote
Old 06-10-2017, 04:14 PM   #2
funky2nite
Drives: 2013 Hybrid 1.5L T4
Yes it does have obd2. Our 2013yaris T4 1.5L comes with and OBD2 next to driver's right knee is (for RHD) is the connector. Mine worked fine with this: Real ELM 327 V 1.5 Bluetooth Android OBD v2.1 OBD2 Scanner Automotive EOBD CANBUS OBD 2 Diagnostic Scan Tool V1.5 ELM327 OBDII
http://s.aliexpress.com/IZ3eyAZJ
(from AliExpress Android)
As i needed to read actual rpm for testing hybrid's tranny as the hybrid rpm gauge isnt meaningful in terms of exsct rpm car is doing.
Hope this helps
funky2nite is offline   Reply With Quote
Old 12-04-2017, 04:38 AM   #3
Tia
Drives: benz
Yes,it does have OBD2,
I recently purchased the Launch CReader 4001 . This automotive scanner supports reading and erasing DTCs, I/M Readiness Status. I'm using this for my Toyota prius Plug In 2014 and working fine. Its helps me to see live data stream, turning off Malfunction Indicator Light (MIL) and help me fix them quickly and efficiently,and it was easy to use and easy to understand.I think this is a must have for any car owners.
https://www.amazon.com/dp/B06WP4KY24
Tia is offline   Reply With Quote
Genuine Toyota Yaris Hybrid Chrome Exhaust Pipe Finisher PZ467-B7490-00 ucsmfu Cosmetic Modifications (Exterior/Interior) 3 10-04-2014 02:45 PM
