Old 06-03-2017, 12:28 PM   #1
Bony_ahmed
Drives: Toyota Yaris SEdan
ABS solenoid relay location
where is the abs solenoid relay location........mine is 07 yaris sedan. handbrake and abs light keeps on always....ive checked the code....it shows abs solenoid relay short circuit.......need help !!!
Bony_ahmed is offline   Reply With Quote
Old 06-03-2017, 01:59 PM   #2
tmontague
tmontague's Avatar
likely corroded sensors at the hubs. Not sure if there is a way for you to isolate the specific one.
If you do end up replacing them, fill them with dielectric grease to keep out corossion
Old 06-03-2017, 02:41 PM   #3
SirDigby
Drives: 2007 yaris 3 door
the ABS relays are in the engine bay on the right side of the battery. there is a 50A and a 30A. if those are good, there might be an issue in the abs pump or the wiring. usually if there is an issue in the wheel speed sensor, there is a specific fault for that, but it still might be an issue.
Old 06-04-2017, 08:43 AM   #4
Bony_ahmed
ive checked the sensors at wheels....sensors are okay.....lets see if the relays are fine.....thanx guys :D
DIY - Exterior lights on when doors are remotely unlocked CTScott DIY / Maintenance / Service 21 07-31-2025 06:30 PM
First Generation Vitz ABS Issue Owais Yunus DIY / Maintenance / Service 0 10-29-2016 11:14 AM
Noise From ABS when Braking + ABS & (!) Light On - Please Help Chris Jackson DIY / Maintenance / Service 2 04-23-2016 12:00 AM
What's with ABS? jgag123 Canada 9 01-01-2009 06:04 PM
