![]() ![]() ![]() Drives: yaris 2009 Join Date: Nov 2014
Cluster is saking on 2009 HB
Hey guys,
I Haven't posted something in a while. Here I am tho, I have a problem with my digital cluster. I own a 2009 HB, with the cluster in the middle. In the last 2 months it's saking badly when I go on a bump or if the road is not smooth. It's like something is loose or out of its place. Has-had anyone the same problem?? I can post a video too later to give you a taste Sent from my iPhone using Tapatalk |
![]() ![]() ![]() Drives: 07 5dr Join Date: Nov 2015
The gauge cluster is held on only by two Philips screws so I would suspect that one of the screws is loose or missing. It's very easy to get to the gauge cluster, just pull off the two vertical plastic trim pieces around the radio and then pull the gauge cluster trim up and towards you. The only tool you need is #2 Phillips screwdriver.
Here's a video of a guy removing the three trim pieces (in under 15 seconds). https://www.youtube.com/watch?v=VyWAXdO_83w |
#3 | |
Thanks mate I will check it out. It's weird tho, because it doesn't seem that the screw is loose or missing. In normal roads, it's in place. But in the bumps it's saking up and down. Not left and right Sent from my iPhone using Tapatalk |
| FS: 2009 OEM tachometer gauge cluster | mrbond | Items for Sale by private party | 8 | 05-24-2013 12:00 AM |
