![]() Drives: Toyota Yaris 2007 Sedan Join Date: Sep 2017
Disturbing Noise
Hi everyone. On my 2007 Sedan, there is this very disturbing sound that appears to come from under the engine bay or under the car when I step on the accelerator in low gears.
It sounds like a rattling or two metals vibrating against each other. It only happens when im driving slowly and especially when I'm climbing even the smallest hill. By the way, it's an automatic. What could be the cause? |
Exhaust shield? You'll have to get under there to check it out, if you can't then take it to a shop.
![]() ![]() Drives: 2012 Toyota Yaris 1.3 -3rd Gen Join Date: Aug 2017
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Yea, you can take it off, I just tied mine at the bottom with some wire.
^agreed, tends to rattle more under load at lower rpms ie: a/c on while at idle
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Mar 2013
It’s probably the heat shield on the header. Mine rattled when idling with the AC on. I just took it off. No problems.
#9 | |
Sir Rustalot
Drives: Toyota Yaris silver 2000 reg Join Date: Sep 2017
If it wasnt for my modesty ,i would be perfect !
| shh shh shh noise at tickover | monkeydave | DIY / Maintenance / Service | 0 | 08-16-2017 08:44 PM |
| Colour Collection 05 Reg (UK) brake noise | JLx | DIY / Maintenance / Service | 0 | 07-14-2015 07:56 AM |
| metallic noise when accelerating | poida | DIY / Maintenance / Service | 3 | 03-29-2015 01:20 AM |
| Help With Reverse Noise???? | JoshW | DIY / Maintenance / Service | 0 | 09-09-2011 01:27 PM |
| Radio noise.. need help | TinyGiant | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 12-06-2008 05:21 PM |
