![]() ![]() Drives: yaris 2005 Join Date: Mar 2016
Coolant advise
Hi
Can anyone advise please re the coolant i think i need top up Sent from my SM-G930F using Tapatalk |
To top up just about anything will do as long as it says compatible with all types on the bottle some where. The Toyota red or pink stuff is good for a very long time in my experience.
Stick with Toyota pink I wouldn't advise mixing coolants. There is a company called "OEM" that is sold out here in Canada that makes coolant for all brands and their Toyota/Lexus stuff is has the exact same ingredients as the factory Toyota stuff according to the MSDS sheet.
#4 | |
If it's only slightly low just top it up with distilled water.
#6 | |
Sent from my SM-G930W8 using Tapatalk |
See attached i think i need top up
If it happens only once you can just use distilled water.
If you are flushing complete system then give it whatever there was before. If it was pink, let it be pink. While original Toyota is obviously the best, you can use virtually any pink coolant available. |
![]() ![]() Drives: 07 Yaris Hatch Join Date: Aug 2017
Does anyone know the total capacity? The radiator sure is small....
This stuff works for pink... https://www.amazon.com/Pentosin-8115...s=pink+coolant |
#10 | |
![]() Here is a direct link to the Toyota manuals... https://www.toyota.com/owners/resour...als/yaris/2007
#11 | |
![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
If its just a tiny bit, I just use regular water or better distilled water.
| coolant reservoir/upper radiator level | tmontague | DIY / Maintenance / Service | 4 | 11-05-2014 09:11 AM |
| Various problems with service at shop (green coolant and accelerator rattling noise) | LilyOfTheYaris | DIY / Maintenance / Service | 4 | 04-08-2014 10:31 PM |
| Khameleon Coolant? | LilyOfTheYaris | DIY / Maintenance / Service | 18 | 04-08-2014 10:27 PM |
| Alternatives to Toyota "pink" super long life coolant | Camberix | DIY / Maintenance / Service | 10 | 03-30-2011 11:42 AM |
| coolant reservoir? | toad | DIY / Maintenance / Service | 10 | 11-02-2010 11:02 AM |
