![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Key buttons wont lock/unlock doors.....
(EDIT UPDATE)
Fixed thanks to Mickman.For future reference step 5 could cause the procedure to work or fail.I tried with 3 times on/off and that did the trick,it may be 1 or 2 on/off's for others though. Yarisworld to the rescue again :D I put in a brand new battery,dome lights work so no blown fuses. The small red light on the key itself lights up when pressed. Toyota wants $50 just to diagnose never mind fix. Not sure what to do.Suggestions welcomed. Last edited by Pinchlite; 11-20-2017 at 01:53 PM. |
![]() Drives: 2006 Yaris RS Join Date: May 2015
Try following the reprogram procedure. I had the same problem as you, and reprogramming fixed my issue.
http://freeremoteinstructions.com/to...ris-2006-2010/ |
#3 | |
I will give it a try and report back. |
#4 | |
Looks like I will just get used to using the key the old fashioned way.Cant afford hundreds of dollars to get fixed. |
#5 | |
Fixed!!!
Holy smokes it worked! Step 5 was the issue.I chose 3 on/off's and then the doors locked.All is good. Thanks for the help big time! |
key
| New remote key fob programming | costica | DIY / Maintenance / Service | 1 | 04-17-2016 08:02 PM |
| Transponder key programming | teddy | DIY / Maintenance / Service | 6 | 04-28-2015 06:32 PM |
| Lost key (transponder and remote lock/unlock) | shyeoh | DIY / Maintenance / Service | 4 | 07-11-2013 05:04 AM |
| Yaris Key fob wont lock my doors! | Treeny | DIY / Maintenance / Service | 3 | 03-29-2012 07:27 AM |
| lock/unlock buttons | matthewai | Cosmetic Modifications (Exterior/Interior) | 9 | 01-14-2011 12:00 PM |
