Old 05-25-2007, 04:41 PM   #1
nsmitchell
nsmitchell's Avatar
Drives: LB-Auto-PWR-ABS-Cruise-Springs
Crazy DFCO Idea
I don't know if it is possible in any way, but what if DFCO could be activated each time you press your brake pedal. Can you imagine the gas savings.
Does anyone think this is feasible, worthwhile or poppycock?!
Other car is a 2005 Mustang Convertible 4.0L V6 Manual - Legend Lime
Get YarAss in gear!
RIP - Casey Tatum
nsmitchell is offline   Reply With Quote
Old 05-25-2007, 08:10 PM   #2
BailOut
Steals terrorist's lunch
BailOut's Avatar
It wouldn't be hard to get this going. Just put a push switch under the arm of the brake pedal, and hook it to a relay that's in-line with the power to the fuel injectors.
I don't think it would be worthwhile, though. DFCO while braking is already achievable with the MT by just not clutching, and in the AT by leaving the gear selector in 3 or L while braking.
- Brian
Share the Road
Old 05-26-2007, 12:49 AM   #3
nsmitchell
nsmitchell's Avatar
So if I put my auto in 3rd when I brake, DFCO will activate. I'm gunna try this one out.
My brother pointed out an obvious problem. Your engine would cut off at stoplights. It would need a sensor to cut DFCO off under say 10MPH to keep your engine running and also to minimize drivability issues.
Get YarAss in gear!
RIP - Casey Tatum
Old 05-26-2007, 12:53 AM   #4
BailOut
BailOut's Avatar
As mentioned in my DFCO thread the ECU cuts the injectors back on when your resistance RPM drops below 1,100.
- Brian
Share the Road
Using DFCO to increase your MPG BailOut Fuel Economy Forum 216 08-30-2018 04:15 AM
Is this a dumb idea...... mgthompson General Yaris / Vitz Discussion 7 03-31-2007 08:17 PM
I Don't Think My Yaris Has DFCO Kaotic Lazagna General Yaris / Vitz Discussion 27 03-30-2007 05:37 PM
Muffler Tip ~ Good Idea? jaspie Cosmetic Modifications (Exterior/Interior) 14 01-17-2007 07:34 PM
Install a Yaris deck into a Matrix... bad idea?? Help needed!! SimmZ In Car Entertainment + Electronics (audio / video / alarm) 4 12-17-2006 01:01 AM
