Old 03-27-2018, 06:09 PM   #1
agent86
Drives: 2016 Yaris LE
Bumper end pops out
2016 Yaris LE. Any suggestions on fixing an issue where the bumper end pops out when jarred (passenger side only). I pulled it out to demonstrate the extreme case.
agent86 is offline   Reply With Quote
Old 03-27-2018, 10:12 PM   #2
Dodge Aries K
My Yaris is a "racecar"
Drives: 2007 Yaris hatchback
If it's under warranty have it fixed for free. Otherwise try replacing the clip on the fender or just glue it in.
-Karl the Uber/Lyft Driver
Dodge Aries K is offline   Reply With Quote
Old 03-28-2018, 09:27 AM   #3
agent86
Glued it. Hopefully it will hold up.
https://www.jbweld.com/collections/e...bonder-syringe
Old 03-27-2018, 10:57 PM   #4
SirDigby
Drives: 2007 yaris 3 door
racing brackets.
https://images-na.ssl-images-amazon....1wZ0RcHoAL.jpg
http://www.ledin.us/media/catalog/pr.../l01-430_4.jpg
https://sc01.alicdn.com/kf/HTB1V3yLN...Xq6xXFXXXZ.jpg
Old 04-02-2018, 02:03 AM   #5
yarisimean
Drives: 2012 Yaris 3d LB
My 2012 yaris has the same problem on the the passenger side too. Although, it is not as pronounced as yours. I usually just pop it back into place, but after awhile it pops back out.
Never thought about using those passwordjdm quick release to keep it secure. May try that if it gets worse.
yarisimean is offline   Reply With Quote
Old 04-02-2018, 01:10 PM   #6
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
I hope you don't need to do any work on the front end, like replacing a headlight. There isn't enough room behind the headlight body to pull the main bulb. You really need to remove the bumper fascia to remove the lens assembly. I ended up getting new clips for mine, but I've taken the front end apart probably 20 times since I've bought it for one reason or another. The bumper itself is also worn, so that's part of the problem. I have dreams of upgrading the '09 to the '12 or '15 cosmetic upgrade when I've got a spare $1k laying around. =)
Old 04-02-2018, 01:43 PM   #7
The 3rd gen does not have the same space constraints as the 2nd gen and can be done without the hassle of popping the bumper cover and removing the light assembly.
Old 04-04-2018, 01:17 PM   #8
CrankyOldMan
Interesting! Thanks for the info!
Old 04-22-2018, 09:35 PM   #9
sherlockholmes
sherlockholmes's Avatar
Drives: Yaris 09
What about the radiator? I have seen people completely removing that.
(you know best so I am waiting to know )
sherlockholmes is offline   Reply With Quote
Old 09-12-2019, 08:52 PM   #10
knobby bobby
knobby bobby's Avatar
Drives: 2015 Yaris Coupe
same problem here 2015 yaris coupe. same side passenger side. I was thinking about removing the entire front plastic and mount a tubular steel bumper. Toyota stealer prolly wants $175 for a plastic clip that is made to break. Toyota gives you the best quality motor and drive train 2nd to none and then surrounds it with cheap plastic crap. Totally redundant.
knobby bobby is offline   Reply With Quote
bumper joint retainer
FS: Full NCP91 KavinT Manseth Kit (Front Bumper has Damage) Treyz Items for Sale by private party 22 04-08-2014 06:17 PM
Rear bumper partial detachment caused by wind D-Flo DIY / Maintenance / Service 3 11-21-2013 06:15 PM
FS: JDM Vitz RS Front (2009) and Rear (2007) Bumper (AZ and Possibly So Cal) jmew0ng Items for Sale by private party 23 10-05-2013 12:24 AM
New Bumper Cover CB900F2 DIY / Maintenance / Service 6 01-18-2010 06:49 PM
2009 Front Bumper Conversion with foglight 808yarisLB Cosmetic Modifications (Exterior/Interior) 25 01-03-2009 12:47 AM
